Old 01-13-2014   #1
zr-1.R1
Default post only, restore my zr-1
first of all I apologize for my bad English by google translate.
peaks is my first series 1990, 59,000 km and two owners, was stopped three years.
the first thing I changed the spark plugs, they were wrong, changed the oil, checked that the vacuum pump would work and that the system vacuum was ok.
now the car is better, but at least occasionally miss a beat.
also in acceleration is not very bad.
the first thing I ordered the inettori overhauled to SFI guaranteed three years now I wanted to ask before installing them, the plastic plugs SFI told me not to remove them, is that right?
I will stop for now, later on other questions, thanks
zr-1.R1 is offline   Reply With Quote
Old 01-13-2014   #2
zr-1.R1
Default Re: post only, restore my zr-1
I forgot the injectors are bosh, however, are marked ford?????
is this normal??
Old 01-13-2014   #3
Using ford motorsports injectors is a common replacement. You will need the O-Rings on the Secondary injectors; on the primary you do not need the O-rings and plastic retainers on the injector. On the primary the injector o-ring is in the injector housing and the body of the injector will seal there.
Old 01-13-2014   #4
scottfab
scottfab's Avatar
The injectors look to be the correct ones for a 1990 ZR-1.
I think the plastic must come off. Take pictures with plastic off
for us to see.
The "Ford" stamp indicates manufacturer of the injectors not
the car it can go into.
Scott
Old 01-13-2014   #5
zr-1.R1
the black plastic on the injector does not come off, the manufacturer SFI demand removal so he told me, word for word:
hi, leave the caps on. They are not to be taken off .
now the ones with the blue cap I should be so, while on queli with black plastic, I have doubt !
Old 01-13-2014   #6
Leave the blue cap on the secondary port
Old 01-13-2014   #7
Schrade
After you get a translation result in Google Translate, take the result OF English, and do a reverse translate, BACK INTO Italian, and see how it comes out in Italian. You will be surprised. This will show you what words for which you might need a synonym.
Most of the time, it's not too important, since English and Italian are rooted in Latin. But occasionally, it IS important...
Old 01-13-2014   #8
zr-1.R1
doubt lies in the secondary injectors, in many photos I've seen them like this.
the photo is on the site of SFI, which is why I have doubts?
Now what to do?
forcibly remove the black cap?
Schrade ok, with a couple of tries, you get a very good result
File Type: jpg $T2eC16h,!)kE9s4,BtsDBRVli!rR,g~~60_57.JPG (139.0 KB, 9 views)
Old 01-13-2014   #9
Schrade
Give heed to the advice of those people on the forum [website] boards here (after concensus), and NOT so much to the vendors of the parts.
Old 01-13-2014   #10
zr-1.R1
ok schrade , other tips?
black plastic cap on this?
