![]() Join Date: Jan 2010
Anyone know the best place (and part numbers) to get rear hatch struts and those short ones (about 6'' long) you can install on the unused "studs" for the hood?
Do the short struts make any difference when lifting the hood? I think GM discontinued them after 88 or so, but left the "studs" Thanks |
![]() Join Date: Mar 2008
This post provides info for the short hood struts: http://www.zr1.net/forum/showpost.ph...37&postcount=5
![]() Join Date: Nov 2011
Doug, I did the short struts on mine. Definatly makes opening the hood easier. From the upright position, you have to push it closed. Bought them from e-bay. I think I asked, and none of our regular friends (Jerry and others) had them.
![]() Join Date: Apr 2007
After Gunny turned me on I added the short ones to my 94 and they sure make the hood a lot easier to handle.
![]() ![]() ![]() Join Date: May 2007
I have a post up on this somewhere they are real cheap from rock auto.
#6 | |
![]() Join Date: Mar 2009
There is a company on ebay (PartsHighway) that sells struts made by StrongArm,. They sell the single long strut as well as the smaller struts used from 1984 to 1988. I read a post in the past where a ZR-1 owner just added one of the small struts in addition to the original longer single strut.
Two USA-Made Hood Lift Supports (Shocks/Struts/Arm Props/Gas Springs) 4003 One USA-Made Hood Lift Support (Shock/Strut/Arm Prop/Gas Spring) 4972 Two USA-Made Hatch Lift Supports (Shocks/Struts/Arm Props/Gas Springs) 4903 4904 I purchased struts from this company in the past for the trunk of my Lexus. I was glad to find parts that were made in the USA. Ken Last edited by KGV; 01-12-2014 at 12:55 PM. |
#8 | |
If I pull the hood down about 6 inches and let go it will actually go back up to full open ![]() Hood Support Source TIPS
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-12-2014 at 01:07 PM. |
#9 |
Thanks for all the info!
The Brotherhood is a great resource! Doug |
#10 |
![]() Join Date: Jul 2005
Last year I replaced my rear hatch struts and weatherstripping. Bought the parts from the dealer for $475. I know expensive. He also installed them for me for $261. That was for struts and weatherstrip. The new struts make a world of difference!
JB 1990 #148 Red/Saddle Haibeck AYBKG5 Chip/RC Engineering/Flowmasters/K&N/Samco/Fuzzy Dice :cheers: |
