Old 01-11-2014   #1
ghlkal
ghlkal's Avatar
Question Is this the correct sending unit?
I ordered a sending unit for my 1990 ZR-1 last November. I was hoping to put it in during my Christmas break. My fuel gauge is way off and I didn't want to mess with opening up the old one and trying to clean the contacts, etc, and the replacement unit was a good price.
It just arrived and I won't have a chance to look at this for a few weeks, but ... is this the correct sending unit?
I know we have two fuel pumps, but there's only one electrical connector. Since I haven't removed the old one, I don't know if this is the correct part or not.
Does anyone know?
Thanks
1990 ZR-1 #2180 Red/Black
Many of the usual mods for 460HP, tuned by Marc Haibeck
ZR-1 Net Registry Member #1548
Old 01-11-2014   #2
Default Re: Is this the correct sending unit?
I think you nailed it. One connector, one pump.
http://jerrysgaskets.com/store2/root..._image&pID=575
Old 01-11-2014   #3
I wonder if the sending unit could be cannibalized and attached to the old jig. Course, by then one may as well R&R the old sender, I spoze...
Old 01-11-2014   #4
Does anyone know?
Thanks
I concur with Jerry it appears to be the correct pump and sending unit
Old 01-11-2014   #5
The way I read it, Jerry was agreeing that it was a single pump/sender unit.
And, the photo of the unit Jerry linked to has 4 wires on the flat connector; black, red, gray, green. The one in ghlkal's photo has only 3 wires; a ground plus one for the (single) pump, and one for the sending unit? ghlkal's is a single pump unit - or so it appears t me. No?
P.
Old 01-11-2014   #6
Blue Flame Restorations
Paul, that's what I was seeing also. You guys had me confused! LOL
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 01-11-2014   #7
ghlkal
ghlkal's Avatar
So, Jerry, the correct one does have two connectors, one going directly to each pump, right?
Mine has two connectors total, but only one for the pump. The other connector you see there is for the wiring harness. And as Paul noted that connector only has three wires (black, gray, purple) and I assume I need 4.
Darn ...
Thanks for your help guys.
Old 01-11-2014   #8
Yeah it does not match the one Jerry linked:
Old 01-11-2014   #9
I was referring to the single I thought Jerry was too my bad yep not the correct dual unit
Old 01-11-2014   #10
Sorry, I should have worded my reply better. I tend to be less "wordy" when I'm on my phone.
YES, 2 connectors to the pumps, 1/pump. Other connector plugs in to harness.
