12-12-2013 | #1 |
Does your exhaust choke your engine?
I guess, check out the difference in top speed on a 415
This 1995 #Corvette ZR-1 415 CID LT5 was featured in the August 1998 Issue of Road & Track, that was John Lingenfelter’s yellow 1995 ZR-1 for the top speed shootout. Mario Andretti drove all of the cars at the Fort Stockton test track and Lingenfelter's yellow ZR-1 ran 201.5 MPH with full exhaust and 218.1 MPH on open headers. This 415 CID LT5 produced 686 HP and is normally aspirated. The 1995 Corvette ZR1 415 CID is owned by Norm Koerner
12-12-2013 | #2 |
Re: Does your exhaust choke your engine?
Funny you should bring this up. When Marc dynoed my 91 this week as it was cold out the first run he had an exhaust tube on to run the gases outside even with negative pull on it. he said the numbers came lower than suspected by a fair amount, Next runs he opened the door much better results.
So in his words yes flow makes a difference. |
12-12-2013 | #3 |
I'm suspecting my Turq "Z" is a non issue for restriction.
I'll let you know for sure once my hearing comes back to normal.
12-12-2013 | #4 |
Always an interesting topic!
I'm at 432 rwhp (read my signature for details) but still have the Magnaflow muffs with the 2.5" restriction (abrupt...restriction), and stock TB. Marc suggested a minor improvement to my porting, back when he was doing a spot of welding on my IH. I made that correction. Now, I;m itchin' to see how close those three tweaks get me to 450 rwhp, w/o going to cams or electric water pump (cams = 20 - 25, water pump = 10, TB maybe 5, 3" Dynamax 17228s maybe 3-4 more, the "510" mod = X? Getting close! There is just sooo much potential locked up in these LT5s. I mean it is getting common place to approach or exceed the same power level at the wheels with the LT5 as the contemporary Corvette motors are making at the flywheel, in spite of using stock cams and giving up 18 or so cubic inches displacement. Gotta wonder: What were they thinking???
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 12-12-2013 at 03:57 PM. |
12-12-2013 | #5 | |
12-12-2013 | #6 |
The reason I am going to Corsa no cats over flowmasters.
Marc said with the extra head work he did better flowing exhaust would make better use of it. Possible 20hp!! over cats and flowmasters.
12-12-2013 | #7 |
well I've got the stock system, so yes
12-12-2013 | #8 |
Ok apparently lingenfelter got busted by the Road and Track police; they had L98 cats on the car so it looked to comply with the rules, they got caught with a bypass switch that went to open headers. So R&T made them run it with the L98 in use at WOT. Busted!
The following week they ran the same car with high flow cats and still hit the 218!
12-13-2013 | #9 |
The difference between a loser and a winner , can be the one that can tweek the rules better. Ask any true drag racer.
12-13-2013 | #10 |
The ultimate Tweaker was Smokey Yunick.
