![]() Join Date: Nov 2013
Hello,
does anybody know what the rear wheel offset is for a zr1. I bought 17/11 rears and they sent them for a regular corvette. I cant seem to find any for a original zr1 so I am wondering if adding a spacer would make it work. The salesman made a mistake when he sold me these wheels but I cant seem to find any that actually have a zr1 offset amold that are deepdish also. Will a spacer work? the guy at the tire place said get a 1 inch spacer and that should do it. Any help will be appreciated. edramos. |
there are no aftermarket deep lug rears on the market. the rear offset is 36mm I believe
36MM is the correct rear offset. 50MM is the rear offset for a Grand Sport
#4 | |
![]() Join Date: Oct 2004
Definitely a NO on the 1" stuff. The fellow who did mine I understand is in poor health these days and isn't near you at all. If I can help at all ask. I know where I'd go if I needed to do them again and my old reliable fellow couldn't do them but maybe you'd rather maybe buy correct wheels. What do you actually have for wheels now? Are you attempting to add "black" GS or just what? Last edited by WVZR-1; 11-25-2013 at 06:43 PM. |
![]() ![]() Join Date: Feb 2010
Carter200 on this forum makes the hubcentric spacers you need.
14mm is that about 1 inch?? I can get hubcentric billet 1 inch spacers no problem.
25 mm in a inch. so 14mm is just a little over half inch spacer. I thought it would be more?
ok I will look around for 18mm hubscentric spacers. thanks.
#9 |
I threw my pitted amolds away today. I thought these would fit but they dont. I am in a pickle and need to make these work. the hubcentric spacers are spacers that mount on your hub with bolts and then you bolt the rims on to them. I dont think I will need new wheel studs just more bolts. I found a company that would make 20mm. Let see if I can find 18mm. I contacted carter200 to see if you can sell me some. thanks for your help. edramos.
#10 | |
