Old 11-16-2013   #1
Z06scentair
Z06scentair's Avatar
Default ZR-1 on the lift for the first time.
Ok put the car on the lift today to browse around. Found the oil pan missing one bolt, and two exhaust manifold bolts missing. One on the drivers and one on the passenger side.
Where can one obtain these three replacement bolts?
Z06scentair is offline   Reply With Quote
Old 11-16-2013   #2
mike100
Default Re: ZR-1 on the lift for the first time.
the oil pan one is metric- if you don't need the exact stock part, you could source that locally, but you could probably get one here on the forum.
Are you sure about the manifold bolts? The stock manifolds only use like 7 of the available 16 holes drilled into the cylinder head. the one on the back corner is one of the ones GM did not install and most people freak out when they first notice it.
Old 11-16-2013   #3
Z06scentair
Yeah I would like to find a correct bolt if I can. NCRS bound
You may be correct, it was the rear missing on both sides. Will check it again tomorrow.
Old 11-17-2013   #4
Z06scentair
Found an oil pan bolt and fixed that. Most of the oil pan bolts were loose.
There was a ton of oil/ grease build up on the bottom side of the car that had blown back across the floor pans, trans tunnel, rear end housing. Found that interesting for a 20k mile car. All that is spic and span now thanks to simple green!
It looks as though the root cause of that oil residue was from the oil cooler lines. Someone at some point did some brazing on the connection crimps and solved that problem.
I noticed some undercoating had been used on the front feet portion of the floor boards? Would this have been from the factory or has someone added such?
Old 11-17-2013   #5
tpr60
Factory undercoat on the floor pan was done at Bowling Green plant.
tpr60 is offline   Reply With Quote
Old 11-18-2013   #6
Z06scentair
Thanks I wasn't really sure!
Old 11-18-2013   #7
Schrade
Take the camera with ya' there while cleaning?
Snappics are good!
Old 11-18-2013   #8
Z06scentair
Snappics are good!
Man
I was in such a hurry had to pull the midyear out take it across the road because of the rain coming in. Run back across the street put the z on the lift.......just didn't have time.
But when your down at thanksgiving you'll get a birds eye view!
