11-14-2013 | #1 |
"Sys" flashing
Hello everyone,
Got in my car this am and as I drove off I see "sys" flashing in the digital cluster. What does this mean and how serious? Backstory: notice has never come on before. But Sunday night I left the interior light on and Tuesday go to start it and the battery is beyond dead. Jump the car, starts right up. Let it charge a bit and then shut it off. Get in this am, battery a little weak but starts. I drive off and everything seems to be working fine other than the "sys" notice. So I have to believe it's tied to the battery getting drained. Any insight appreciated. |
11-14-2013 | #2 |
Re: "Sys" flashing
The battery has an internal short. You will see this just before your battery dies however make sure your battery is fully charged first. The only other explanation is after an aftermarket radio install which yours is not. However plan on buying a new battery. If you continue to see this message after you have fully charged the battery.. then trust me new battery time. GC
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 11-14-2013 at 12:11 PM. |
11-14-2013 | #3 |
Re: "Sys" flashing
Someone correct me if I'm wrong but, I'm pretty sure the "SYS" light will flash when the CCM has detected a problem. I bet you have a code set. You can manually retrieve the code and reset or hook it up to a scanner.
Joe 1990 Bright Red ZR-1 #2599 |
11-14-2013 | #4 |
Re: "Sys" flashing
Thank you. Load off my mind. It's an acdelco battery. ..maybe original but doubt it. No aftermarket radio or components. Battery replacement is something that won't keep me up at night.
11-14-2013 | #5 | |
Re: "Sys" flashing
A "SYS" code is 99.99% of the time a warning just before the battery craps out.
11-14-2013 | #6 |
Re: "Sys" flashing
I have an otc genesis scanner. Seems to work "ok" in communicating with the car. It Def won't clear my ltpmd light. But I will hook it up and see if it reads any codes.
11-14-2013 | #7 |
Re: "Sys" flashing
Go Boldy
11-14-2013 | #8 | |
Re: "Sys" flashing
Pull the bulb in the DIC and that light will go away. Or repair or replace the defective bands
11-14-2013 | #9 |
Re: "Sys" flashing
Ahh, did not know that. I was quoting the '90 owner's manual. Thx
11-14-2013 | #10 |
Re: "Sys" flashing
GC was 100% correct. got into it after my breakfast meeting - "sys" light gone. I have to think since I didn't drive it after jumping it and letting idle/charge it was prob still reading a very low charge. But after driving it to my office - no "sys" message at all and things be well. Good to know for next time.
This board/group is the most impressive collection of people and knowledge I have personally come across in any specialty car environment. Makes owning cars like this much more enjoyable and a little less scary. Thanks everyone |
