Old 11-11-2013   #1
bradley
Default tools needed to replace head gaskets
I need to find out what tools I need to buy to replace the head gaskets in my 90, and where I can get them ? can anyone give me a list. I already have the gaskets needed just need the tools to do the job
bradley is offline   Reply With Quote
Old 11-11-2013   #2
Default Re: tools needed to replace head gaskets
You have to pull engine. And you need a good torque wrench for Head Bolts and a set of metric flex head ratchet wrenches and set of 3/8 metric sockets. And a set of Torx T handles.
Harbor Freight has a nice engine lift and transmission
Jack
Old 11-11-2013   #3
What Cliff said its a pull the engine time. You will also need an engine puller etc and it's a bear of a job
Old 11-11-2013   #4
mike100
I'd mostly be concerned on how to re-time the cams. The rest of it looks like pretty standard tools required for r&r portion. Ben has some clever substitutes and tricks in his LT5 repair thread which would be a good read I would think.
Old 11-11-2013   #5
bradley
the cam timing tool are what I really need to find out about .pulling the motor isn't a concern.
Old 11-11-2013   #6
Default Camshaft Timing Tools
All you need is a 15/64 drill bit to pin the camshafts
You also need timing chain mechanical tensioners.
Or you can visually even get closer if you want to advance the pinning hole in the camshaft a bit past or before the pinning hole in the Camshaft Retainer.
Camshaft Timing
Camshaft Timing (Locking the Camshafts) and Camshaft Lubrication
I have removed the Heads with engine in car but then camshaft timing as well as Head Bolt Torque application is almost impossible with engine in car.
Pull the C-Frame, the Transmission, Bell Housing, exhaust manifolds....pull Plenum and IH to make it easy. I have actually installed the LT5 with Headers attached
Oh.....I pulled windshield wiper motor and cover off AC Evaporator just to get those out of the way for easy engine installation.
Old 11-11-2013   #7
cvette98pacecar
Jack
Seriously Harbor Freight? Let me say ~&*^%$# upfront before you smash your knuckles.
Old 11-11-2013   #8
Default LIfting the LT5 and ZF S6-40 Transmission
Yep....and lifted LT5 engines as well as ZF S6 40 transmissions several times with no issues with knuckles
Lifting The LT5
ZR-1 Transmission Install and Lift Tricks
Old 11-14-2013   #9
phrogs
phrogs's Avatar
I made my own timing chain tensioner a for camshaft timing and used the drill bits above. I also used the ARP bolts Marc Hiebeck sells for the camshaft timing gears.
You do not need the lt5 tools to do this job.
You can do it with the engine in the car but it's just easier to yank it out.
JOHNNY P
Currently own
