Old 10-15-2013   #1
Y-me
Default LT5 with an auto?
I know anything is possible, but how Feasible is it to hook an LT5 to an auto and have an ECM run both? I know the input shaft on a ZR1 ZF6 is a different length than an L98 or LT1 version, so how would one go about finding an auto for a combo that never existed? Also woul one just have to run an LT5 ECM and ditch the electronic 4L60E for a Hydrualic 4L60?
I ask because I am kicking around the idea of dropping an LT5 into my LT1 94 auto.
Y-me is offline   Reply With Quote
Old 10-15-2013   #2
Default Re: LT5 with an auto?
Talk with Pete
Old 10-15-2013   #3
Karl
Karl's Avatar
https://sites.google.com/site/peteszr1garage/
Old 10-15-2013   #4
There is no code in the Stock LT5 ECM for an auto, so you will need to run a standalone controller for the automatic, which is not necessarily a bad thing.
You just cannot run it all from the LT5 ECM,
I believe as long as you use the MEMCAL for a 94 Z your current CCM might be ok, otherwise, that might throw codes (Never tried a P CCM with a J ECM)
Old 10-15-2013   #5
Schrade
I put an auto in my '90, and everyone said a dedicated tranny controller would be easier to wire in, than to re-code the ECM.
Of course, your PCM already is written for auto control, but ISN'T coded for LT5.
Perhaps put in a Z ECM, and wire in the controller. And put in a second fuel pump, fuel line, etc., ...
Will the Dana 30 (or 35?) rear handle LT5 power? Probably...
Old 10-15-2013   #6
Y-me
Car is already converted with a D44 3:45. It's 36 btw.
