Old 10-12-2013   #1
Default Dropped plenum question
While we have some hood restrictions...would it not make more sense to have a topped vs dropped plenum to get the plenum runner further from the ceiling/wall? As in adding the volume to the top of the plenum?
Any thoughts?
Old 10-12-2013   #2
Default Re: Dropped plenum question
Old 10-12-2013   #3
Kevin
Kevin's Avatar
big runners and dropped is so sexy....that's about as helpful as I can be
Old 10-13-2013   #4
Coupe89
Isn't the TB the restriction on air flow into the plenum ?
1990 ZR-1 #642
Coupe89 is offline   Reply With Quote
Old 10-13-2013   #5
Bob Eyres
Yes, but you can get a bigger one of those.
Didn't Lingenfelter use the dropped plenum on some early (or all?) 415's?
I would think that with a dropped plenum, and siamesed runners, you would need a BIG stroker sucking on it to keep the port velocity up.
If you did anything to the top of the plenum, you would need a high rise hood. Mine's banging on the hood now, with just those phenolic plenum spacers.
Old 10-13-2013   #6
Kevin
Kevin's Avatar
LPE used the dropped plenum on some cars. Mark Horner's 385 has one, i know others have it also but i can't think of them off hand.
Old 10-13-2013   #7
Blownrunner
I have seen pictures of this on cars. What is it and what does it do? Where does the DIS module get mounted?
Blownrunner is offline   Reply With Quote
Old 10-13-2013   #8
Kevin
Kevin's Avatar
adds volume and the dis box gets relocated to the firewall
Old 10-13-2013   #9
Vette Guy
Vette Guy's Avatar
I have not pulled the plenum on the 385 Z since I've owned it, however Bob Hall tells me that it is a work of art! The DIS has been relocated.... I'll take plenty of photos when the time comes to remove it. I understand that the dropped plenum added quite a bit of torque throughout the rpm range.
I always wondered what happened with Bill Kirchoffer's prototype carbon fiber plenum. Anyone remember seeing it at BG in 2003? I recall it having more space up top and direct ports to the IHs.
Mark Horner
President, ZR-1 Net Registry
91 ZR-1 #2016
95 ZR-1 #21 DRM-600, LPE 385
Vette Guy is offline   Reply With Quote
Old 10-14-2013   #10
Geez Mark , that entire car is a work of art ! Talk about one well sorted out car.
