Go Back   ZR-1 Net Registry Forums > Corvette > Corvette Audio/Electronics
Old 10-09-2013   #1
92whiteZ
Default Speaker popping
Looked though the various threads but didn't see exactly what my issue is:
my passenger speakers occasionally pop/crackle. not all the time and cant consistently reproduce it to see what the cause is. is this what happens just before they fail? as far as I know the speakers/amps have never been out of the car/rebuilt but I have not removed them to make sure.
thanks
92whiteZ is offline   Reply With Quote
Old 10-10-2013   #2
Hammer
Hammer's Avatar
Talking Re: Speaker popping
Sounds like the amps to me. Dr. Don's can fix you up or maybe you can find someone in your area that can fix them.
Old 10-10-2013   #3
Franke
Default Re: Speaker popping
More than likely the amps capacitors are going bad. Common problem on older amps like these. I was able to replace the electrolytic caps and my amps worked again. You can get new amps if desired.
Old 10-10-2013   #4
92whiteZ
Great info, thank you. will look into getting them replaced.
Old 10-16-2013   #5
92whiteZ
was the amps. trying to head back to the junk yard for bose amps this weekend. will try and grab some spares if anyone needs any.
Old 10-16-2013   #6
Bose Speaker Amp Options TIPS
None left in Fresno
The 95' Nissan Maxima Speaker with Amps look like this.....
95' Nissan Maxima Front Speakers..................................95' Nissan Maxima Rear Speakers
All you need are the speaker Amps
