Old 10-02-2013   #1
efnfast
Default Cam grinding
Soooo, how do you grind a cam and give it more lift? Seems to me if you grind it you'll give it less lift. Longer lifters and grind on the closed side? TIA -Steve
Old 10-02-2013   #2
Default Re: Cam grinding
The base cricle is reduced so in relation to the reduced base circle there is more lift
Old 10-02-2013   #3
Default Camshaft Regrinds, Lifters, Valves, and Camshaft Timing
Since you are reducing base circle you have to check Lifters to make sure you do not run out of Lifter uncompressed Height.
See 10 Posts regarding Lifters/Valves/Camshafts LT5 New Rebuild Issues (Lifters and Camshafts)
And......since you now have more Valve Lift you have to check Camshaft Timing to make sure you do not have Valve Interference with Pistions at TDC (the Eyebrows)
CAMSHAFT TIMING
Post 21 - LT5 Camshaft Specifications and Camshaft General Timing (pinning)
Post 22 - LT5 Camshaft Specific Timing (degree wheel)
Post 23 - LT5 Camshaft Timing Additional Tricks
Post 24 - LT5 Timing Diagrams and Timing Chain Effective Lengths
Post 25 - LT5 Timing Chains and Sprockets
Old 10-02-2013   #4
efnfast
Thanks guys, every time I heard about cam grinding had me thinking.
Old 10-02-2013   #5
Bob Eyres
Got me thinking too. I've often wondered why LT5 reground cams are so expensive. Even considering the fact that there are four of them.
If there is a program for the grinding machine, it's not a long "hand labor" situation then it should be a pretty straightforward procedure to do four cams.
Maybe I'm just "livin in the past". Remember the "Corvette Duntov Cam" for small blocks back in the day? What was that? Less than a hundred bucks?
Old 10-02-2013   #6
Profile development costs $, then you have to do 4 of them and as with anything the rarity of the parts
Old 10-02-2013   #7
efnfast
What are the down sides of a more aggresive profile? Idle, fuel mileage, more broken parts?
Old 10-02-2013   #8
The Reground Intake gives you the most additional power....not so much the Reground Exhaust....but let Pete the Cam Guru Explain.
Both XfireZ51 and myself have taken a peak at our reground Cams after hours of run time and found nothing out of order in regard to Camshaft or Cam Journal wear.
Maybe a bit rougher idle (depends if you Regrind BOTH Intake and Exhaust), no appreciable difference in fuel mileage (maybe a bit less), No Broken Parts. Watch carefully when installing Reground Cams regarding Lifters and Camshaft Timing as suggested
Again....here on this Forum Pete the Cam Guru is the GO TO GUY on Camshaft Regrinds as he has proven in his 1/4 mile times
You can ask Pete about Camshaft Hardening which is not an issue with the Camshaft Regrinds as the Camshaft Grinding does not get past the Hardened Surface.
Old 10-02-2013   #9
Blue Flame Restorations
I have Pete's cams in my 91 Turq car. It makes my bone stock Purple 95 feel like a luxury car, in comparison. Man, I'd love to mod that car's engine.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 10-02-2013   #10
Bob Eyres
So, are you saying that with the cams the 91' is quicker, but less tractable and less easy to drive than the 95'?
I wonder if the combination of my light flywheel and the cams will make it a strong runner, but take a whole lot of smoothness out.
