Old 10-01-2013   #1
KJL
Default Steel IH Gaskets & Primary Port is 38mm
Update: Finally got injector housings off and discovered why I had an oil leak at the IH to head gasket, it appears a steel gasket was used...see pictures. Not sure why? I also discovered that the IH primary ports have been opened up to just shy of 38mm. The steel gaskets are also 38mm but the head was not matched to the gasket or IH. Question: why was a steel gasket used and should I proceed with opening up the primary port on the heads to 38mm to match the IH? I will have to trim some material off the new gasket as well.
1995 ZR1 #159
1992 ZR1 #280
1996 Collectors LT4 (Stock)
572 rwhp
Old 10-01-2013   #2
Default Re: Steel IH Gaskets & Primary Port is 38mm
Steel? Never seen those before. Haibeck sells a steel Cometic Headgasket like the LSX motors use but ive never seen steel IH gaskets before. GC
Old 10-01-2013   #3
WVZR-1
Steel? Are you sure? Maybe "aluminum" or there's "copper" choices I believe also.
Old 10-01-2013   #4
KJL
I just pulled one off the head, i believe it is aluminum, it looked like stainless but it is soft. Aluminum would make more sense.
The gasket also appears to be coated with a clear material..... permatex shellac?
Either way, this is a relatively low clamp pressure application, unless the surfaces are perfect, using any type of metal gasket is risky as my leaks demonstrate.
I think I will just match the head to Jerry's gasket instead of the IH which is a tad bigger.
1995 ZR1 #159
1992 ZR1 #280
572 rwhp
Old 10-01-2013   #5
KJL
The gaskets have a "ring" and weight of steel however. Could be a soft stainless?
1995 ZR1 #159
1992 ZR1 #280
572 rwhp
Old 10-01-2013   #6
Got a magnet handy ?
Old 10-01-2013   #7
KJL
Low carbon stainless wont be magnetic either... not a reliable test. I guess material doesn't mater in the long run, I was just curious as to why someone would chose this over a conventional gasket...heat transfer? Warmer IH better?
1995 ZR1 #159
1992 ZR1 #280
572 rwhp
Old 10-01-2013   #8
Stainless was not mentioned in post number #1 just steel. If thats the case yep I concur. Like stated earlier never seen a stainless steel IH gasket before only the newer steel head gaskets.
Old 10-01-2013   #9
Well, that would be up to you. BUT! You ARE going to have some pulse reversion, and laminar flow will actually be less than if the IH's were the same size as the opening into the heads!** At the very least, you might want to spend a little time and open up the runner cross-section to match the IH and taper down into the heads at least a couple cm, if you're keeping them (danged secondaries)! It will will be worth the effort!
Flyin Ryan does some pretty good runner engineering. He mentioned to me that 4% change in diameter for length is about as much as you can get w/o running into (restriction). And, since then, I've run across some reinforcement for that recommendation. Just sayin... After all, it is well within the realm of possibility to touch 400 rwhp with just a top end and headers, if everything is done correctly. IF. (And, it isn't that much effort if you have the IH's off already!!)
Strongly recommend matching the IH ports and tapering into the heads. You'll reap some cheap horses in the process.
P.
Old 10-01-2013   #10
carter200
carter200's Avatar
Listen to Paul. He knows what he is talking about. What number is your 95? Mine is 392 of the 448 made. Good luck and when you are ready to make her sparkle under the hood and on the wheels give mne a shout.
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
