Old 09-15-2013   #1
garyhugo
garyhugo's Avatar
Default Still rattles
Went and had a new dual mass flywheel and clutch kit put in my Z.
It used to rattle at idle weather the clutch was engaged or disengaged, no difference. Now it only rattles when the clutch is engaged. Whats going on?
Gary
90-1572
garyhugo is offline   Reply With Quote
Old 09-15-2013   #2
Default Re: Still rattles
Gary,
What else has been done to your car?
Bad injectors make the flywheel make noise....
Old 09-15-2013   #3
Franke
I'll second that on the injectors causing rattle. Mine was noisy when in neutral, engine idling, clutch out. The new injectors took away the noise.
Old 09-15-2013   #4
garyhugo
garyhugo's Avatar
New RC injectors about 5-6 years ago by Heibeck.
I'm also having a bit of a driveanility issue with a code 44. Left side O2 sensor lean. I changed the sensor yesterday and wow what a difference in acceleration. I'd forgot just how fast it was and it idled smoother for awhile. Then today the idle was rough again. The code 44 was back and the rattle too. I'm tending to believe the rough idle is causing the rattle.
Gary
90-1572
Old 09-15-2013   #5
I'd want to eliminate a fuel delivery issue first: easy enough to do a fuel pressure test, making sure it isn't something like that. And, then too, changing spark plugs, another easy thing, might shed some light on it - go with the AC/Delco copper 41-602s ($2 ea, work great, and if it doesn't cure the idle problem, you can always switch back and keep the ACs for next time.
Just a thought.
BTW, the opening for the O2 sensor wires, leading into the sensor body, MUST NOT be sealed! (Ask me how I know...). Otherwise they'll fail to work properly, as they depend on ambient air to work properly. (Course, a scanner would tell you instantly if you have a problem with the O2.)
I can't say enough good about having either a scanner or a diagnostic software program for a laptop when it comes to troubleshooting. Beats the hell outta "change this and change that" approach. Just sayin.
Old 09-15-2013   #6
scottfab
scottfab's Avatar
Wait till the thing is cold then jack it up high enough
to crawl under and rap each CAT with your fist or
a rubber mallet.
Listen for the rattle.
You could be hearing pieces of the ceramic CAT rattling.
That was the source of mine.
Scott
Old 09-15-2013   #7
garyhugo
garyhugo's Avatar
What do you mean by the wires going into the sensor must not be sealed?
Gary
90-1572
Old 09-15-2013   #8
garyhugo
garyhugo's Avatar
Thanks for the replies. I'm going to let Aaron at SGC find the rough idle problem. I'm sure thats what is causing the rattle.
Gary
90-1572
Old 09-15-2013   #9
Franke
Since you show a code 44 and you replaced the O2 on that side and the problem came back it could be a injector problem either mechanical or electrical. The O2 is ahead of the cat and is responding to what it sees comming down the exhaust. (Lean or Rich) The rattle is more than likely due to the rough idle as that is what caused mine.
