Old 09-12-2013   #1
carmine
Unhappy Help Again
Open Car Door No Interior Lites Turn On Ignition No Radio NO Ant. No AC Heat Control Dash Lites OK Car Starts Fuses Seem OK
carmine is offline   Reply With Quote
Old 09-12-2013   #2
Schrade
Default Re: Help Again
Fuses SEEM ok?
No interior lights, with door open, COULD indicate DAB Delayed Accesssory Bus failure, but we need to KNOW for sure about fuses, before ANYthing diagnostics starts...
ed.:
Harsh reading there Carmine; a few commas makes it easier on the eyes here...
...and did they work before starting headlight work?
Old 09-12-2013   #3
carmine
Have Not Started Headlites ,Gears Backorderd ,Will Check All Fuses Again ,
Old 09-13-2013   #4
carmine
CRSTY Fuse Blown ,Whats The Connection With The Radio ,Heat &ac Control
Old 09-13-2013   #5
geezer
Heater & A/C control assembly ( electronic A/C ) , radio amp relay courtesy lamps, rearview mirror light, console light & glove box light are all on this 15 amp ctsy fuse.
Question is why did it blow in the first place?? & will it hold??
geezer is offline   Reply With Quote
Old 09-13-2013   #6
scottfab
scottfab's Avatar
Do you have any after market additions? Radio or Amp or alarm or anything at all?
What was the last thing electrical on the car you worked on?
Scott
Old 09-13-2013   #7
Kevin
Kevin's Avatar
i had a similar problem when a pen got into my cigar lighter and popped a fuse on my 91. can't remember which fuse it was though, this was early 1999
Old 09-13-2013   #8
carmine
NO Aftermarket Addistions , No electricl Work Done Lately
Old 09-13-2013   #9
scottfab
scottfab's Avatar
Ok, there's not going to be a magic bullet answer to what it is without
a pure guess. So let's not guess. Let's get a few details down.
1. the fuse is blown and is a 15A fuse located in the CTSY FUSE slot?
2. if you put another fuse in it blows?
Do you have a volt/ohms meter?
Scott
Old 09-13-2013   #10
carmine
Fuse Does Not Blow Right Away ,Have Meter
