Old 08-30-2013   #1
Schrade
Default P Side Cruise Module access; gotta' yank the dash? [Snappic]
Anyone been here - Cruise Module under passenger side dash? FSM says start with jumpers on a couple of the CCM circuits under P side dashboard. Can it be accessed from under the dash on P Side? Or does the dash have to come out?
Radio Receiver Box = Data Control Module??? Or are they 2 different varmints?
Old 08-31-2013   #2
gbrtng
gbrtng's Avatar
Default Re: P Side Cruise Module access; gotta' yank the dash? [Snappic]
Remove the radio receiver from below - then you have access to the cruise module. Be durned sure the module is bad first because that stuff is pretty much a mess to work on, especially if you are 73 years old and don't bend easily anymore. Ask how I know ...
Old 08-31-2013   #3
Schrade
Still lost here - is the CC module accessible from under the P side? Or the center console?
Old 08-31-2013   #4
vilant
Don't have time to look the answer up for ya, as I'm ready to leave but, if you go to the parts list in the members section on the home page (I think if you click on members, then welcome) you'll find it has the entire car dissected. Look under electrical or whatever the best category the CC is in (can't remember the categories). Hope that helps.
Old 08-31-2013   #5
Franke
Schrade, the FSM shows that it is accessible from the passenger side by removing the lower RH trim panel then the radio receiver. (The radio receiver is a seperate box from the radio control head in the center part of the dash). The CC unit is screwed on to the radio receiver box on the top.
Old 08-31-2013   #6
mike100
I was able to get my radio rcvr out, without much disassembly, but putting it back in was a little harder. I think I just was able to reattach one side of it with the 10mm screw and jammed a little foam in there somewhere to keep it from bouncing around. You have to be careful to not break one of the plastic mounting ears...or just velcro the whole mess back in there (which is exactly what they ended up doing on the 94-96 cars when they relocated it to the rear storage bin).
Old 08-31-2013   #7
gbrtng
gbrtng's Avatar
see my message #2 - the word "below" has meaning.
Old 08-31-2013   #8
Schrade
Got it there Franke - just got the back-killer (p side seat) out, for ease-of access...
Probably is everything there, Vilant - except what I need.
No mention anywhere of the control module, or 'surging Cruise', after following 1st 4 links with 'Cruise' search criteria...
I got it all forthwith here...
Old 08-31-2013   #9
Schrade
Does this lower carpeted panel separate from under the dash?
[img]http://www.zr1.net/forum/attachment.php?attachmentid=2627&d=1377991841[/url]
Old 08-31-2013   #10
geezer
Shrade; If memory serves There is an attachment screw hiding in the fuse holder area to the left.
geezer is offline   Reply With Quote
