Old 08-28-2013   #1
Default AC switches intermittent
Yesterday I was running the A/C (95 degrees in Chicago) and for a while a few of the switches on the A/C console didn't work. The temp change button wouldn't work except to increase the temp (by the time I was done experimenting it was up to 82 degrees). Also the Off button wouldn't work. Tried a few of the others and they seemed to work. Later in the day they all seemed to work. Am I facing the imminent failure of the A/C control head? Car has only 24k miles. Maybe switches are giving up due to old age? (My pass window switch is also getting a bit iffy. At some point soon I will pull the door panel to see if I have a loose connection.) Has anyone experienced the A/C switch issue and is there a solution? -- Bob
Old 08-28-2013   #2
Route 66
Route 66's Avatar
Default Re: AC switches internittent
I am having the same problem with my A/C/ If you find a fix would you please let me know. With a PM....Thanks Route 66.
Route 66 is offline   Reply With Quote
Old 08-28-2013   #3
Franke
Sounds like a poor connection since it seems to change with heat. I would check ground to the control head and AC Programmer module or the connectors themselves. Page 8A-68-0 In the FSM.
Old 08-29-2013   #4
Yes Franke, when all else fails I suppose I should read the manual . That is a good suggestion-maybe grounds but I am confused by the fact only a couple switches are affected. The "Off" switch doesn't work but once in a while with a hard push it will. I am afraid to touch temp so I have it set at 74 degrees and use the fan switch to slow things down. All switches but "Off" and "Temp" seem to work. At some point when I get a chance I will start serious diagnosis. Thanks--Bob
Old 08-29-2013   #5
John Boothby
John Boothby's Avatar
You need to remove the a/c control head and then remove the face and clean the button contacts. I did this with mine and it works perfect now. Use an electric contact cleaner and q-tip to clean. Easy to do.
John Boothby is offline   Reply With Quote
Old 08-29-2013   #6
Concer with this recomendation. Cost to try is almost nothing as well
Old 08-29-2013   #7
Franke
Yep. What John and Gold said. Hope that fixes it for ya. 20 plus years of service can cause dirty contacts. Bet the door window switch is the same.
Old 08-29-2013   #8
Thanks to all of you. I think I will be cleaning switch connector contacts in the near future. It does sound like the logical explanation. And as you might imagine, the A/C seems to be working today. --Bob
Old 08-30-2013   #9
Pete
Pete's Avatar
Bob,clean the contacts, Bob G. had the same issue in his low mile 1994 Z took it apart and cleaned the contacts and works been just fine for 3 years.
Don't you just love low mileage Z's
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 08-30-2013   #10
scottfab
scottfab's Avatar
As with so many of the issues that come up on the car this is an old and repeating one. Yes by all means clean the contacts. The reason they fail is oxidation. The metals used are a cheap tin alloy. Cheaper than it should have been.
Coat them with dielectric grease when re-inserting the head contacts.
This keep oxygen away from them prolonging the time it takes to oxidize. It's not the buttons it's the connector.
There is another thread somewhere on this but I'll restate the cause from the perspective of a classmate of mine who holds a PhD and 26 patents in the field of metal to metal contact issues. It is the result of dendrite growth and oxidation.
Scott
