I have a 1994 it sometimes will not crank when hot and I have seen "SYS" flashing in speedo sometimes? I did bypass the chip on the key and still have problem. any ideas
![]() Join Date: May 2013
I've seen this come up as a bad starter motor or defective wiring connection between the starter and battery. SYS could be flashing due to a heavy drain on the battery when trying to start. Check battery voltage with a digital voltmeter when trying to start hot. Voltage should stay above 10.5 or so according to some manuals. IMHO. Any others got some insight?
#3 | |
![]() Starter Relay, Wiring Harness, Battery, and Plugs Tricks
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS |
I have a new batt I have been told to replace the starter relay under dash some where? allso was told it could be bad control modual? has anyone heard of that?
![]() Join Date: Mar 2007
Starter Solenoid is heat soated.....has the starter been replaced???
#6 | |
![]() Join Date: Jan 2009
When it won't start measure these with the key turned: 1. From the engine block to the Pos on the battery 2. From the Neg to the Pos on the battery Don't assume a new battery is a good battery. From there, assuming above ~11V other places should be measured....
car has 20k on it I believe its the starter that came with the car. will check voltages next time it dont crank but I feel as if the batt is fine. was looking for the location of the starter relay?
It's going to be under your left knee cap. You'll have to remove the cover but that is only a couple of screws on the front part and I think one fastener toward the firewall. On your car (not mine) it should be the relay closest to the steering column.
#9 |
thank you we will give it a try
