![]() Join Date: Apr 2013
I took my drivers seat out today to fix a couple things. The side bolsters wouldn't move, and of course the lumbar pump didn't work. Got the side bolsters to work (I think it was a loose wire to the switch - works now). I did this fix http://www.zr1.net/forum/showthread.php?t=4659 on the lumbar pump and got it to run and put some air out the tubes when I hooked it up off the car. Got everything back together and the pump runs like a champ. Only problem is that I ran it for probably 30 seconds or so and couldn't feel any inflation on any of the 3 bladders? How long is it supposed to take before you feel the bladders inflating? And I have no idea how much pressure is supposed to come outta that pump - you could feel air coming out? The hoses and all that I could see without removing the actual seat cover from the foam looked good. Pliable and connections were tight...
And the wife wanted me to ask if there was a way to add cushion to the seats? Other then the obvious one which would be to put one IN the seat..??? |
![]() Join Date: Nov 2011
Mine pump up pretty quickly. 10-15 seconds. 23 years old, could be dry rotted lines or blown bladders.
Other than that obvious answer about putting more padding in the seat...... |
bladder leaking?
I don't know. Not sure how I would tell either without disassembling the entire seat from the foam.... Was hoping I could get the pump running and all would be good. Not my luck.....
#5 | |
![]() Join Date: Jan 2012
Racinfan, if the pump works then I would suspect there are tears in the bladders which is also common. Unfortunately, you'll have to dig into the seats to check.
I'll let you know. |
![]() Join Date: May 2013
Racinfan83,
When I had my seats redone with new foams and covers the upolstery guy swore at them for having the lumbar support bladders in the foam. Seems they are a PITA to work with. However after the work was done they are working great and feel good too. Quote from the upolstery guy " now I remember why I hate redoing these sport seats" ![]() |
![]() Join Date: Mar 2004
Seat Mod's
Remove lower portion of seat by releasing the 2 spring clamp's under the front of seat. Lift up seat bottom and disconnect air tubes etc. Check and feel that the trapeze strap's still have spring left to them. I replace the trapeze strap's and cover the sharp wire's with small diameter tubing. Go out and get some heavy duty juke padding and lay it on top of the trapeze etc.. Then reinstall seat bottom and secure the clips. It's easy as heck and fast to do. The trapeze as they are called can be had from Mid-America or Eckler's.......and they are 2 for each @ 70 buck's for 2 seats. Everything else is cheap and easily found locally. You and your wife's bun's will love the mod. Mine did ! seat trapeze: http://www.corvettemods.com/product....FY2Z4AodBX4A1w Any question's PM me with your number. Last edited by FU; 08-14-2013 at 02:31 PM. |
#8 | |
I took the entire seat out to do the pump fix - it's actually really simple to get out. The "trapeze" things on mine seem to be in really good shape (car only has 18k miles on it) I haven't taken out the passenger side yet - still trying to figure out the drivers side...
I talked with one of the Mechanics at work - he suggested I try airing up the bladders with an air compressor at like 2 psi, or using one of the 12 volt compressors you fill air beds with - just to see if the bladders/hoses hold air. I think I will try that when I get some time - just to see if maybe the pump fixed with the dish glove diaphragm isn't putting out enough.. What is that "juke" padding you mentioned?? Like memory foam or not? May have to try that but wondering exactly what it is... ![]() Quote:
#9 | |
Just wondering. |
#10 |
Google juke padding, there are lot's of choice's there. Just don't get one that is too thick or you'll have a tough time putting the seat bottom clip's back on.
Only 2 trapeze strap's on the seat's that I have seen. Make sure they still have spring left in them. While your in there protect the seat foam. t\To avoid the metal wire's etc. from digging into the foam. Turn the seat bottom upside down and you will see what I'm trying to say. |
