![]() Join Date: Mar 2004
Anyone have any luck using spherical bearings on the front and rear suspension with any luck ? They are supposed to give a "smother and more sophisticated ride". Also "free moving bushing, gives you a more compliant ride, without loosing any of the sports car handling"
With our stock bushing's starting to get worn loose and cracked, I was looking at these for a more modern route. |
![]() Join Date: Dec 2003
I have them on sway bar linkage, rear tie rod ends & camber braces. Definitely noticed a more positive handling feel and I like the idea of my rear camber being rigid instead of floating around in rubber. I didn't notice any adverse effects. I also have coil overs, poly bushings on the sway bar & front a-frames and about to install poly on the U & L Trailing links (dog bones).
Video :
http://www.youtube.com/watch?v=6qgAX...BE8GmzaM8JlXVA Link : http://www.newmancarcreations.com/products/ The spherical bearings would be very useful with a coilover car IMO. |
Neweman has some of the best C4 Dana 44 upgrades around. Go for it Frank, lead the way.
that looks pretty cool
I agree--the effortless movement of the rear suspension pieces in the video look like they should significantly improve the ride and handling. Has anyone used the Newman setup in the rear? - Bob
![]() Join Date: Dec 2004
Isn't this the same concept?
http://www.banskimotorsports.com/C4_...spensioin.html or this from Dick Gulstrand? http://www.guldstrand.com/scripts/pr...p?idproduct=65 I like that you high HP guys have a way to get a better center section. That's neat workmanship and the diff selection is sweet too. ![]() Tom
Banski Motorsports :
360. for 4 bones plus 220.00 for 2 camber rods. Fully adjustable. ![]() Guldstrand motorsport : 506.00 for each pair of bones . Fully adjustable ![]() Newman car Creations : 699.00 using your rear dog bones.Non adjustable. Newman front 860.00 (all 4 must be sent) Ballistic Fabrication : 480.00 for all bones. Must be welded in place. ![]() There is a jungle of these thing's we can get into. I just showed Newman for his product's. I had some of his D44 HD parts on the white car I used to own. With our older suspension's needing attention in the future these may be a better alternative than rubber or poly bushing replacement. Last edited by FU; 08-10-2013 at 08:33 AM. |
#9 |
Frank, I wasn't trying to be a wise guy. I was just thinking "where did I see the concept before?" and I searched my favorites because I just knew I had something like the Newman stuff.
I agree as my car's suspension stuff is getting way long in the tooth. I will just share this tid bit I got from a conversation with VB&P, because they offer the same Heim-joint equipment...."NO, not for street use!" was what they told me. Now there are a couple of the WAZOO guys that did the Banski complete rear work up, even Daryl did his Z too, and they just opted for the banski stuff with the covers for all the joints to keep the dirt out. I would like to see if they have any thoughts as they have some miles on their set ups. ![]() Tom
#10 |
No wise guy Tom. Good conversation great.
One of the reason's that Newman was brought into the picture ? Was because his stuff look's more for street duty than the other's. Plus there is a feast of aftermarket product's for our car's in all the link's that you posted. We all are going to have to be keeping our eye's open for these kind of improvement's as our car's age. And want to keep the newer car's wondering why we still are a threat. |
