edit: It's now a different problem:
It's now a 'Hardware Not Found' issue (for TunerPro 5.0). DataMaster - Z1 says, "ALDL is working, but no PCM detected." I did download the '90, '91 LT5 version from DataMaster website. Help? Last edited by Schrade; 08-03-2013 at 03:09 PM. |
![]() Join Date: May 2013
Shrade,
I had to download a similar uart driver for my laptop as it didn't have a usb driver for my TTS datamaster as well. Go on the web and type in the search box ft232 uart usb driver. I beieve you will find one you can use. |
#3 | |
It's now a 'Hardware Not Found' issue (for TunerPro 5.0). DataMaster - Z1 says, "ALDL is working, but no PCM detected." I did download the '90, '91 LT5 version from DataMaster website. Help? |
![]() Join Date: May 2005
Are you using a serial to usb converter? I had to use the software that came with the converter to get my FJO dual wideband setup to work. I am going to try Tunerpro tomorrow, will let you know.
Tyler |
#5 | |
"Disable CCM Handshake" ( a recognition problem ), did not fix the problem. They have to do better than this............... |
Changed COM port to port 4; CCM detected.
Still no readings displayed... |
Got a connection with monitoring.
Looks like some problems somewhere here (will Copy / Paste readings shortly for feedback from TUNERS!!!). edit: DataMaster didn't record a DIACOM file to play back. WTH??? Last edited by Schrade; 08-03-2013 at 09:44 PM. |
Schrade,
What version of datamaster are you using and what year is your car? |
#9 | ||
#10 |
Try recording a datamaster file and playback of the datamaster file instead of diacom
