Old 08-02-2013   #1
Default New Radiator??
Hey, y'all!
I'm in the market for a new radiator (to replace the broken one on my Z).
Suggestions/prices for a replacement radiator??? Frankly, the stock one with Marc's fan control program was more than sufficient for even some spirited hwy driving, so I don't think I need to go bigger.
Thanks in advance!!
P.
Old 08-02-2013   #2
Default Re: New Radiator??
Thanks in advance!!
P.
The question is "was the stock radiator sufficient to handle stop and go driving when the outside air temps approach 100 deg F"
I would just go with a Ron Davis Aluminum radiator and be done with it
1. Ron Davis Radiator w/o transmission cooling
a. 1989-1996 C4 Type V8 All Part No. 1-16CV8996
b. Rated 800 Hp
c. Manual transmission
d. For the Ron Davis radiator the fan shroud inside baffles have to be cut back 5/8 inch so there is not contact with the fins of the radiator. Use a small cut off grinder for that task.
e. I cut the tab on the passenger side of the fiberglass radiator housing (the single tab with larger bolt hole that interferes the most with the oil cooler hoses). The fiberglass radiator housing then slipped on easily without further modifications.
LT5 Radiator and Initial Coolant Fill Tricks
Old 08-02-2013   #3
Kevin
Kevin's Avatar
if you use a stock replacement you'll end up with one for an auto car I think. I'd rather go aftermarket and then be able to pump fluid into the rad at high rpm then not
Old 08-03-2013   #4
Pete
Pete's Avatar
Paul i have a stocker for you come pick it up.
Just wash it/clean it and your all good.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 08-03-2013   #5
b. Rated 800 Hp
LT5 Radiator and Exhaust Install Tricks
Thanks for the "future info" Cliff. I'll put that in my LT5 "stuff" file.
Old 08-03-2013   #6
Pete
See PM
Old 08-03-2013   #7
Blue Flame Restorations
When I rebuilt EX5023 I just bought a six speed radiator from the local parts store. ZR-1 application.
Pete's Dman!
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 08-03-2013   #8
I'd agree w Cliff. Just driving the ZR around a few weeks ago w the A/C on(picked up the wife from work) H2O temps went to 230 until I could get on the road. But stop and go is an issue with temps at 90+ and A/C.
Old 08-03-2013   #9
PhillipsLT5
PhillipsLT5's Avatar
Ron Davis is high end
I went with Fluidyne years ago
Old 08-03-2013   #10
garyhugo
garyhugo's Avatar
I agree. Went with the fluidyne years ago and it has handled the Florida weather for thousands of miles without incident.
Gary
90-1572
garyhugo is offline   Reply With Quote
