Ok so I started this in the knock sensor holding you back thread and decided to start a new one. After replacing some injectors the car ran great. It sat a few weeks and the customer picked it up and said it was running worse then when he brought it to us. So after the weekend i came back in to see this black beast staring at me. I go and drive it and sure as hell its running like it did before i did the injectors. So i pull the plenum per my boss and recheck the injectors all ohm good none leaking all spraying. Put the plenum back on it and go to start it, Nothing. Found the starter had crapped out. So off the plenum comes again 3rd time in 3 weeks, get down to the starter and low and behold, a mouse created a home. Plugged the drain chewed on the purple starter wire and managed to kill the starter with his lil rat bladder. Got the starter in put the car back together (which im getting pretty good at if i dont say so myself). Hit the key it fires up, running nice and smooth, sweet thought i fixed it. NO (car god smacks me in the face). Pretty sure I got it down to a ignition miss, anybody have any tricks to finding a miss? Pulled plugs all look good like its running great. Regapped and reinstalled but the miss is still there. If anybody has any suggestions or ideas I'm all ears.
Car is a 92 with 24000 on the clock OEM AC Delco plugs, driven not beaten. |
No codes? No Closed Loop codes?
Short of that, can you post a datalog scan? |
![]() Join Date: Jan 2007
If I saw a mouse had made a home under the plenum I would have checked all the wiring and the plug wires. Those buggers are noted for chewing through wiring shields to make their nest. It maybe grounding out from a bare wire. 24k tells me it sits a lot even if an garage the mice can get to it, personal experience.
No codes, seems to be going through o2 loops like it should. Yeah checked all wiring didn't find anything but the starter wire chewed on. Found moister in cylinder 8 plug well dried it up, seemed to take care of the miss. Now its got a hesitation sag when you jump on it. both in neutral and when driving down the road. If you ease through the throttle seems to be OK. Something to ponder through the weekend its almost 4 and 100+ in the shop i am out for the day. Thanks for your thoughts and suggestions not real familiar with the LT5's.
Did you say you checked the fuel system? Pumps, strainers, fuel filter by passenger front?
![]() Join Date: Mar 2007
2ndry map sensor under the ECM?
verify secondaries are opening, you can see them inside the plenum.....
#7 | |
Could be wrong tho'. |
![]() Join Date: Aug 2008
This is what I'd do if my Z started to act up like the above described. I'd force it to throw an SES which in turn will store a code. If its stumbling when you get on it than you need to really get on it. I can almost assure you that when you hit somewhere around 7k the SES light will appear in the information center and will turn off when you back off of the throttle. And there's your code. I was also going to suggest checking to see if your MAP sensor hose is plugged in. It sounds like a stupid thing to overlook but I think we've all done it at one time or another. That will cause terrible idle and run like crap. Once it's plugged back in it will purr like a kitten. But the code will tell you where to look.
#9 |
![]() ![]() Join Date: Feb 2010
I had an intermittemt miss that turned out to be a weak fuel pump. replaced both pumps and problem went away.
You need codes to appear
#10 |
I had a knock code throw at one point. That's what brought me to this forum. But I haven't been able to get it to come back. The vacuum hose to the map sensor on the back of the plenum is new. The only worry spot I just thought about is the elbow that connects the two Pcv valves to the vacuum tube. Come to think about it they seemed pretty sloppy, it's got hose clamps on the bottom side. Any way to seal the top better without buying a new elbow. That could be part of the off idle stumble/hesitation. Been a long hot week maybe next week on a fresh brain will help. I'm sure it's something dumb.
