![]() Join Date: Jul 2013
![]() ![]() Hello all, happy to be here with you all. I just purchased a 1991 ZR-1. White, with both tops, all original, and only 19,400 miles. Car is pretty flawless, with some very minor trim issues. The car arrived with its blue tint roof panel on, and only yesterday did I take the painted top out of the hatch. Around the interior of the painted top are four rubber peices. They were detached, and came in the rear storage bin. The two-sided sticky tape is still on the top, but obviously isn't sticky anymore. What are those pieces for? Seems it would just be black painted metals under the sticky tape? Don't know if I should remove old tape and reinstall, or leave them off after removing the old sticky tape. Appreciate any input. Thank you. John |
![]() Join Date: Nov 2011
They're "head bumps". Don't think I ever bumped my head on them.
Welcome to the forum. -Steve |
![]() Join Date: Apr 2004
Congrats and welcome. I would just get some new tape clean and replace or use contact cement. I believe you should have one on each side the other 2 go on the other top if they are not there.
Edit there are 4 two in back and 1 each side, just got mine out and looked, its been in the closet for the last 11 years...
Steve 1990 Steel Blue/Black #2355 1990 Red/Red #1473 1991 Quasar /Black #118 Sold 1991 Turquoise/Black #766 Parted Out 1993 Yellow/White #179 Sold 1990 Black/Gray #1361 Headers/4:10s Sold Last edited by We Gone; 07-17-2013 at 07:40 PM. |
Thanks for the prompt responses! Head bumps...darn lawyers!
I will attempt to "cleanly" remove the old tape, and see how it looks, if not I will re-attach. Thank you all again. John |
Welcome onto the boards there...
If the rubber isn't dried out, a THOROUGH wipedown with Trans-X will do it good. That stuff permeates the rubber, and softens and swells it. Closest thing to 'miracle-in-a-can' that I know of. SHould give a good seal after re-installation. And some snappics of the car are acceptable on the boards here!!! |
![]() Join Date: Feb 2006
Wear a helmet and you will see why they are there.
![]() Join Date: Jul 2010
