Have some barely used (500miles) injectors out of the 427. These are Delphi units (Lucas style). These flowed 23 lb/hr @ 40psi. This is 26 lbs/hr at 50.7 psi, which is the LT5 rail pressure. For completeness, this is 24 lbs/hr at 3-bar (43.5 psi), which is the normal rating pressure.
Will let all 16 go for $200. Todd Pepmeier |
TTT. make an offer.
Al, and Bob G should jump on these.
![]() Join Date: Jul 2010
Good deal there.
![]() Join Date: Mar 2006
Does anyone know if these injectors work in a 91 ZR-1?
Need to know if they are a drop in replacement. |
![]() Join Date: Oct 2013
I don't think he meant he needs them, I think he was asking if they were a stock sized replacement.
They would fit, but flow too much for a stock car. If I recall, stock is about 21 lb/hr. |
#8 | |
Stock inj. Run at ~23#. |
#9 |
Are they too much for my stock '90?
Can anyone on the boards do a spray test? This car is the only fuel injected car I've owned, that turns over 4-5 times, sometimes a second key pull, before it fires. I really think a spray test is in order. Short of a spray test showing what I have now, I'm VERY interested, just to have them ready, at that price... |
#10 |
I have a 368 cubic inch, Cory Henderson built, with a 63mm throttle body.
Stock cams, just wondering if these injectors will be too big? |
