Old 07-13-2013   #1
janozr1
Default A C SWITCH
hi , need to get part numbers of this two switchs and also asking you which one open coolling fans when pressure will be to high ?
thanks ,Jano
janozr1 is offline   Reply With Quote
Old 07-13-2013   #2
Hammer
Hammer's Avatar
Default Re: A C SWITCH
The small one on the left in your picture is the fan switch.
The parts CD I have shows the following numbers:
90-93
AC Delco #15-2351 Switch, AC Compressor Eng Cool Temp (Fan Switch)
AC Delco #15-2352 Switch AC Cycling (High Pressure Switch)
94-95
AC Delco #15-2878 Switch AC Compressor Eng Cool Temp (Fan Switch)
AC Delco #15-2877 Switch AC Cycling (High Pressure Switch)
Old 07-14-2013   #3
janozr1
ok , thanks ,this i need to buy
94-95
but cant find where , any other part nmb ? I have two pin connector.
jano
Old 07-14-2013   #4
Hammer
Hammer's Avatar
Talking Re: A C SWITCH
For your car the GM part number is 10223909
Hope that helps.
