Old 07-05-2013   #1
Jagdpanzer
Jagdpanzer's Avatar
Default 402 Build Project Udate
Finally had some time to finnish assembling the 402 motor I've had in the works for awhile. Before buttoning up the cam covers and oil sump wanted to make sure the oil galleries in the block and heads were filled and flowing properly before firing the engine for the first time so I put together this pre-oiler rig. Used the regulator and gauges from my leak-down tester to control the air pressure at 10 psi.
Converted 2 gallon hand sprayer I picked up at Home Depot. Installed a air line quick connect fitting in place of the safty valve.
Engine connection point is the plug fitting located at the top side of the oil filter housing. Made a couple of plugs out of delrin to block off the oil cooler fittings. Inserted a short section of clear hose for a flow visual.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 07-05-2013   #2
dredgeguy
dredgeguy's Avatar
Default Re: 402 Build Project Udate
Boy does Wazoo have talent. Great Phil and looking forward to seeing it in operation.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 07-05-2013   #3
That's all Phil!!!!
Can't wait to see this in action
Old 07-05-2013   #4
Racinfan83
No doubt that is cool! Get a video up of it working if you can!
AND - on another note - just what does WAZOO stand for?
Old 07-05-2013   #5
Corbusa
very cool !! thanks
Old 07-05-2013   #6
about damn time
Old 07-05-2013   #7
Jagdpanzer
Jagdpanzer's Avatar
about damn time
Lee, remember this one?
http://www.youtube.com/watch?v=bpj0t2ozPWY
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 07-05-2013   #8
HA!
Old 07-05-2013   #9
secondchance
Fantastic! Can't wait 'till the 402 is in your Z.
Old 07-05-2013   #10
secondchance
Washington Area ZR1 Owners Organization.
