Old 07-02-2013   #1
Default Seatbelt questions
So I know how the 'cinch' button works.. I also know under harder acceleration the seatbelts lock.
What I am curious on is if after a hard acceleration is the belt lock suppose to release to become loose like newer cars? or is it suppose to stay locked..
Old 07-02-2013   #2
Default Re: Seatbelt questions
I think it will remain tensed until pressure/load is released from the belt
Old 07-02-2013   #3
Right I think it should as well.. but it does not release when pressure/load is released..
if it should operate the way we think then I need to figure out the issue
so I need to somehow confirm operation of the belts
Old 07-02-2013   #4
secondchance
Jeff,
Based on my experience with C4s since 1984 (including 91 and 94 Z) is that once locked (or cinched) only way to unlock is unbuckle and retract all the way back then pull and re-buckle.
Old 07-02-2013   #5
PhillipsLT5
PhillipsLT5's Avatar
mine acts like secondchance
Old 07-02-2013   #6
Franke
Jeff,
The FSM states: "When the vehicle decelerates rapidly the belts are locked in position by a pendulem that causes locking bars to engage sprockets on both spools of the retractor. The shoulder portion of the belt has a comfort feature that allows the occupant to adjust the shoulder belt portion for proper fit and comfort. The lap portion has a cinch feature that allows the person to lock the lap belt into position. The cinch feature does not interfere with the operation of the shoulder belt and retractor. Once the cinch feature is activated it can only be released when the belt is fully retracted. This is also important for a child seat restraint system". Second chance is right about this.
Also, the chevy dealer told me 2 months ago that my 1990 ZR-1 had a seat belt service bulletin but they couldn't perform it because the car was too old. They asked if my seat belts were working properly and I said yes. Section 10-11-1 has the belt info in the FSM.
Old 07-02-2013   #7
Cool I will check it out thanks
Old 07-02-2013   #8
Mystic ZR-1
Mystic ZR-1's Avatar
Your dealer lied to you. A safety recall never goes away.
Last year GM went thru hoops to do the recall on my 90.
However I didn't let them do it, they could only find blue seatbelts in their system. My car is red. I found NOS red seatbelts at a dealer in MO but they wouldn't use them due to liability even though they were in GM custody all those years. I have to give them credit for trying. The recall is still open on my car. I ended up using used belts to replace the ones that seized up. Used seatbelts are readily available. Only catch is the recall may not have been done on them.
Old 07-03-2013   #9
Franke
Thank you Mystic. I didn't know that about safety recalls.
This isn't the first time a dealer lied to me about my car. The people on this forum know more about these cars than the dealers do. The last service person I talked to didn't know the difference between a regular 1990 corvette and the corvette ZR-1.
Old 07-03-2013   #10
Mystic ZR-1
Here's the safety recall numbers, have the dealer look up your VIN and see if they've been done.
GM addressed this problem with Product Safety Recall N910059 & 058 (ex 91059 - 058) in October of '91.
