Old 06-25-2013   #1
msorenso
msorenso's Avatar
Default Limited Slip Type?
I am a new ZR1 owner and was just curious what type or brand of limited slip did gm use in a 91 ZR1. If I am not mistaken they used a Dana 44 Rear end as well. Thanks for the help!
msorenso is offline   Reply With Quote
Old 06-26-2013   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Limited Slip Type?
Manual transmission equipped C4 Corvettes from 1985 on, including all model year ZR-1s, came with the Dana Super 44 (D44HD) as standard equipment. Nothing special about the ZR-1 version. Dodge Vipers also use a version of the Dana Super 44. The "Super" designation is due to pinion input shaft and bearings being beefed up to Dana 60 splines and yoke size and use the Dana Trac Lok clutch pack type positraction differential unit.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 06-26-2013   #3
msorenso
msorenso's Avatar
So would that be a Dana Model 60 Trac Loc or Modle 60 Trac Lock? Thanks for the help
Old 06-26-2013   #4
msorenso
msorenso's Avatar
Sorry I meant " or 44 trac loc" if there is such a thing? I found a model 60 Trac Loc service mauaul on line.
Old 06-27-2013   #5
batchman
When we rebuilt the LSD in my wife's 88 Z51 I bought the kit for the D44HD. Worked perfectly. Didn't need a manual, and in fact it would have been twice the work if we'd followed the GM manual. No need to remove the batwing, and when you get the center section on the bench you just rotate and the LSD pack out walks out of the housing. That should (hopefully) make sense when the time comes, wish I'd taken pics.
Best,
- Jeff
Old 06-27-2013   #6
Jagdpanzer
Jagdpanzer's Avatar
Here is a photo of a Dana 44HD Trac-Loc LSD:
and where you can buy parts and a replacement unit:
http://www.tomsdifferentials.com/201...Pages25-28.pdf
Dana Spicer Service Manual download:
http://www2.dana.com/pdf/5313-3.pdf
and here's a good DIY rebuild thread:
http://www.corvetteguruforum.com/mod...topic_id=17573
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Last edited by Jagdpanzer; 06-27-2013 at 03:42 PM. Reason: added service manual link
Old 06-27-2013   #7
msorenso
msorenso's Avatar
Cool Re: Limited Slip Type?
Thanks guys!!!=D>
