Old 06-12-2013   #1
oricale
Question Alright!, new car and first troubleshooting!!!!
So I have the car and I want to get some opinions on a issue.
Key off Runs fine no issues....
Key on runs fine until I hammer it and she hesitates (all gears)
PO said he used to have a burned chip in it and now it's stock. Has a B&B exhaust and I think that's it.
The hesitation is not extreme where the car is falling apart its just stuttering from 3800 up.
[B][I][COLOR=red]1990 ZR1[/COLOR][COLOR=black] [U]#00077 [COLOR=red]RED[/COLOR]/[COLOR=red]RED[/COLOR] (10Y022 PEP CAR)
[/U][/COLOR][/I][/B][B][I][COLOR=red]1991 ZR1[/COLOR][COLOR=black] [U]#00517 ("Irene")[COLOR=red]WHITE[/COLOR]/[COLOR=red]RED-SOLD:cry:[/COLOR] [B][/B]
[/U][/COLOR][/I][/B][B][I][COLOR=red]1992 ZR1[/COLOR][COLOR=black] [U]#00445("The Revenant")[COLOR=red][COLOR="Black"]BLACK [/COLOR][/COLOR]/[COLOR=red]RED(2016 T.O.D!) [/COLOR] [/U][/COLOR][/I][/B]
[B][I][COLOR=red]2009 [COLOR=red]Z06!![COLOR=black]BLK/BLK rare Linen interior[/COLOR] 707HP!![/COLOR] [/COLOR][/I][/B]
[B][I][COLOR=red]2006[/COLOR] BLK/BLK Z51 (Just SICK FAST!)SOLD)[/I][/B]
[B][I]1996 BLK/BLK LT4 Grnsprt(sold...Twice!)[/I][/B]
[B][I]1991 RED/REDL98(Fell off the shipping truck:([/I][/B]
[B][I]1980 BLK/RED L82(Sold)[/I][/B]
[B][I][B][I]1990[/I][/B] RED/BLK(sold.....In Japan)[/I][/B]
[I][COLOR=black][B][I]2006[/I][/B][/COLOR][/I] [COLOR=red]Mustang GT[/COLOR] ([B][I]mach 1[/I][/B])[B](sold)[/B]
[COLOR=black][B][I]1969[/I][/B][/COLOR] [COLOR=red]Mach[/COLOR] [B][I]1(sold in Japan)[/I][/B]
[COLOR=black][B][I]1969[/I][/B][/COLOR] [COLOR=red]Mach[/COLOR] [B][I]1#2(sold)[/I][/B]
[B][I]WAZOO Member...[/I][/B]
[url]www.evolution-motorsport.com[/url]
facebook/evolutionmotorsportengineering
Your Local [url]www.Amsoil.com[/url] dealer/user..
*Victory Loves Preparation*
oricale is offline   Reply With Quote
Old 06-12-2013   #2
Default Re: Alright!, new car and first troubleshooting!!!!
Injectors would be my WAG, I would do a fuel pressure check as well maybe as simple as a fuel filter
Old 06-12-2013   #3
Coupe89
Are you getting a SES light when passed the 3K RPM mark?
If so, you may have a a vacuum leek in the secondary system.
1990 ZR-1 #642
Coupe89 is offline   Reply With Quote
Old 06-12-2013   #4
scottfab
scottfab's Avatar
Good job of listing the symptoms.
Just based on those I'd say you have one of the two secondary actuators sticking a bit. Common if you don't exercise at WOT much.
One way to isolate is to do many WOTs in a row. If the stumble does not repeat every time after that then that's it.
On the other hand if you go WOT and hold it for >10sec and you feel the torque flatten out then it's your secondary vacuum pump or a leak. That is you begin the WOT and all is strong up past 5000rmp then after a bit you feel the power drop off.
Scott
Old 06-12-2013   #5
Schrade
Check H History DTC...
Air filter? K&N? Too much oil???
Did your wife see exhaust color with hammer down?
Put a compression guage on it and check the squeeze? (static compression too / leakdown time)
Old 06-12-2013   #6
I agree. Typical 20yr old issues
Injectors. Coil packs. Spark plug wires. Spark plugs. Fuel pumps
Old 06-12-2013   #7
oricale
Thank you for the responses!!.
The PO said he changed all the coils,wires and plugs. I actually have the stock ones he pulled out. HOWEVER.. I did not get secondary injectors!.
No lights light up, it just feels as though it push bad gas .
also: Opinions please
I am debating replacing the stereo in the car...With the history and provenance that this car goes with should I stay stock or install???
finally:
I asked a few other poeple....My throttle body has a STAMP OF AN RP # AND A SERIAL # on it.
Any ideas??
Old 06-12-2013   #8
finally:
Any ideas??
Yep the secondary injectors.... The fact that you mentioned no SES light No codes, fine at startup however struggles all the way through the power band with key on is a dead give away.
I suggest replacing the Radio unless your considering NCRS.
Take a pic of that stamp and general location
Old 06-12-2013   #9
SteelBlueZR1
Don't forget to check the MAP hose and replace it with new oem unit from Jerry's if it is not original hard line that won't collapse at high rpm... Also check secondary operation with plenum on using the procedure here: http://www.zr1specialist.com/HAT%20W...0Operation.pdf
Finally, don't discount the secondary selonoid switch failing as the cause. My car had similar symptoms and a new selonoid solved the issue... Good luck with your new Z!
Bert Rankin
1991 ZR1 Steel Blue / Steel Blue
#1029
Haibeck chip, slotted rotors, camber brace, C-beam plates, OBX exhaust, Nitto NT555 tires
[SIGPIC][/SIGPIC]
Old 06-12-2013   #10
Blue Flame Restorations
Sounds like since you have an early car that "may" have been used for evaluation PEP, I'd probably leave the secondaries intact and leave the car stock, especially since you already have a nice Z to flog.
Eric can probably help you on the stamped codes on your TB.
Again, congrats on the nice find!
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
