Old 06-04-2013   #1
Fully Vetted
Fully Vetted's Avatar
Default Source for fuel line clamp
Anybody have any idea where I could source this fuel line clamp? As you can see in the pic this is for the hard fuel lines that curve around and drop down on the passenger side.
This clamp is broken and my fuel lines have slid up and are touching and arcing against the blower motor connection at the back. I repurposed some wire loom from elsewhere on the car and wrapped the fuel line until I can locate a new clamp. I haven't been able to locate one through the common parts houses. I may have to hit up Shawn at Corvettenutz but thought I would exhaust all of the possibilities for a new part first.
Thanks in advance, guys.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 06-04-2013   #2
Blue Flame Restorations
Default Re: Source for fuel line clamp
David, you're also missing the aluminum piece underneath the braided hoses. The larger clamp on top can be made from standard heater hose clamps on various Corvettes throughout the 60's and 70's.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 06-04-2013   #3
efnfast
Have one in hand that almost fits. Electrical supply house. Maybe Home Depot. Not exact, but real close
Old 06-04-2013   #4
Fully Vetted
Brett, that's actually the piece I'm after is the piece on the bottom. I assumed it was part of the clamp. Not knowing what else may be missing I thought I would just replace the whole thing. I may just end up fabricating a bottom piece.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
Old 06-04-2013   #5
carter200
carter200's Avatar
David,
Dynomite asked me about machining these so guess it's time. Can you send me your old piece and I'll do a quick turnaround for you on it?
Thanks, Carter
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 06-04-2013   #6
PhillipsLT5
PhillipsLT5's Avatar
more Bling!
Old 06-04-2013   #7
carter200
carter200's Avatar
Originally Posted by PhillipsLT5 View Post
more Bling!
That's the spirit
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
Old 06-04-2013   #8
Originally Posted by carter200 View Post
David,
Thanks, Carter
I made two of my own Fuel Line Brackets but it was not good enough for Carter......
Now if Carter were to Etch in Deep Red 87 Oct or 91 Oct on the end of that bar.
Carter uses CNC Machining and I use a round file
Old 06-04-2013   #9
Fully Vetted
David,
Thanks, Carter
Perfect. That would definitely work. I'll email you...
Thanks, guys.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
Old 06-04-2013   #10
carter200
carter200's Avatar
I made my own Fuel Line Bracket but it was not good enough for Carter......
Cliff,
fill me in more on the engraving you need done? You can fax me at 325.625.5795 if you want.
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
