Old 06-01-2013   #1
CJ_ZR1
Default Camber Brace Help
Pickup up this R-D Camber Brace a few months ago. Finally completed coilover and sway bars installs and now ready to install camber brace before getting an alignment, but having a little trouble figuring out how this brace is installed. Do I have all the parts needed for install? Anyone have good pics of brace to help? Thanks in advance for any info
CJ Daniel
[B]1991[/B] ZR-1 #834 [COLOR=royalblue][B]Steel Blue Metallic/Steel Blue[/B][/COLOR]
[COLOR=red]Frank Approved ZR-1[/COLOR]
[SIZE=1]- Ported air horn, throttle body, plenum and injector housings (Tommy Morrison)[/SIZE]
[SIZE=1]- FIC SS Injectors / Nology hot wires / Screemin Deamin coils[/SIZE]
[SIZE=1]- Fluidyne aluminum radiator and 9 row aluminum oil cooler[/SIZE]
[SIZE=1]- 4.10 gears / Fidanza light weight flywheel / Hurst short throw shifter[/SIZE]
[SIZE=1]- Stainless Works long tube headers / Borla exhaust with x-pipe[/SIZE]
[SIZE=1]- DRM Coilovers / 32mm front 26mm rear sway bars[/SIZE]
[SIZE=1]- ASM bolt in 4 point roll bar[/SIZE]
[SIZE=1]- 93 ZR-1 Sawblades[/SIZE]
CJ_ZR1 is offline   Reply With Quote
Old 06-02-2013   #2
Funracer
Default Re: Camber Brace Help
I have one installed. Stand bye while I get a pic.
Funracer is offline   Reply With Quote
Old 06-02-2013   #3
Funracer
Left Side (drivers side):
Right side (Pax side) looking down at it:
Crossbar running underneath front of the air horn. Tight fight:
Mine is an early one I think 10+ yrs old. Yours may not be exactly
the same. As I remember the DS crossbar-to-short-cornerpiece bolt
was a bi-atch to tighten due to limited access with the tools I had then.
On the plus side, it works great once you get it installed!
Good luck
Old 06-02-2013   #4
CJ_ZR1
Thanks for the quick reply and pics. Best pics I have seen of one installed, there are tons of pics for L98 and LT1 cars but not so much for the Z. I will hopefully have time tonight to take a look and try to install. Thanks again
Old 06-02-2013   #5
Tony Davila
Tony Davila's Avatar
Tony Davila is offline   Reply With Quote
Old 06-02-2013   #6
JimZRyd
JimZRyd's Avatar
What coil overs and sways did you go with? Have heard people talk about c/o's on their Z's but haven't heard much about sways. On my old C5 I went with a c/o system from Pfadt racing and put larger sways from the C6Z51 system. Might be something I do on my 94 down the road. Thanks!
Jim Zorgias
1994 ZR-1 Admiral Blue/Black #245
1996 Callaway Supernatural 450
1990 Callaway Supernatural 490 / CR-1 #7
JimZRyd is offline   Reply With Quote
Old 06-02-2013   #7
CJ_ZR1
I went with DRM coilovers (dougrippie.com) and VBP sway bars (vbandp.com). Went with 32mm front and 26mm rear solid bars. Will post pics soon.
-CJ
Old 06-02-2013   #8
JimZRyd
JimZRyd's Avatar
-CJ
How was your ride after the install? Do you track your car? I'm not a track junky but do like to do some " spirited " driving. When I took my old C5 from stock and added c/ o's, sways, non run flats, and a thicker tunnel brace, and then sat her down in the weeds she was a totally different car. Rode smooth as anything but would stay totally flat through any twisty. Looking forward to your pics! Be sure to show off your stance
Jim Zorgias
Old 06-04-2013   #9
Coupe89
Cool pics. I need to install mine... one day
1990 ZR-1 #642
Coupe89 is offline   Reply With Quote
