Old 05-31-2013   #1
RHanselman
RHanselman's Avatar
Default WTB A/C Compressor for my 91'
Any suggestions on buying a new unit?
My Turbo Car's compressor froze and it ate the clutch. Luckily have have a new clutch...
Thanks,
Ron
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1993 #099 Ruby, Jeal 368 w/Snake Skinner body
1961 White with Red Int
RHanselman is offline   Reply With Quote
Old 05-31-2013   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: WTB A/C Compressor for my 91'
Ron,
Not a bad deal for a NOS.
I picked one up a while back to have on hand.
http://www.ebay.com/itm/NEW-COMPRESS...9#ht_135wt_913
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 05-31-2013   #3
RHanselman
RHanselman's Avatar
Ron,
Thanks Phil...
That is a good deal so I just bought one. Thanks for the link!
Cheers,
Ron
Ron Hanselman
Founding Member #80
Old 05-31-2013   #4
Are you doing a 134 conversion ? The sticker on the backside states 134a not sure if the plumbing will be the same. GC
Old 05-31-2013   #5
RHanselman
RHanselman's Avatar
Are you doing a 134 conversion ? The sticker on the backside states 134a not spur if the plumbing will be the same. GC
Daryl,
Yep, going to 134. I'll be installing the oversize valve stems like I did on my 90 (that I use to have.)
It also looks like the same compressor is used on various other applications. The connection area is removable and replaceable with the type needed for specific applications so I'm not too worried.
Cheers,
Ron Hanselman
Founding Member #80
Old 06-01-2013   #6
I noticed when I had r134a the head pressure was greater and you notice it in the car driving
when I replaced the compressor and condenser I went back to R12..
Old 06-01-2013   #7
Yep very true. I will stick with R12 its way colder than any 134a system I've ever owned. After just redoing my entire AC system that suck gets down to the 50s even in 115 AZ heat
Old 06-01-2013   #8
RHanselman
RHanselman's Avatar
I've had good luck with the 134 so I'm staying with it...
Ron Hanselman
Founding Member #80
Old 06-19-2013   #9
mgbrv8
You could always rebuild your compressor. I rebuilt mine. It is in these pictures somewhere.
http://www.facebook.com/media/set/?s...1&l=bf12a0aa41
Dave
