Old 05-28-2013   #1
WydGlydJim
WydGlydJim's Avatar
Default Drop in Dewitt radiator install pics......
The guy I sold my '90 to had a radiator leakage problem, so we went with a Dewitt direct replacement. Technically this is a drop in unit, and I did not need to modify anything....it was a tight fit though, and I found I had to persuade it a few times. Overall impression though is that this is a very nice option. We liked the all aluminum construction, as one of the plastic tanks failed at the plastic to aluminum tank seam on the old one, and it was only 2 years old. The construction and quality is impressive. I had to pry the fan shroud a little to get it to fit between the end tanks, other than that it fit well, and no modifications were required. I did have to undo the bottom bolts on the shroud, and then install the top bolts first, and install all bolts loose install, and then went back and tightened everything. Things did not want to align properly without doing it this way. I'm not sure if that is required with a stock unit. $325 represents a good value in my book, and this radiator has only recently become available.
2009 LS9
1990 LT-5/sold/Bought my Baby back
1994 Lingenfelter LT-5/sold
1973 LS4/sold
WydGlydJim is offline   Reply With Quote
Old 05-29-2013   #2
Schrade
Default Re: Drop in Dewitt radiator install pics......
Pretty nifty handiwork there!
Old 05-29-2013   #3
Fully Vetted
Fully Vetted's Avatar
What is the other radiator that is available? Is it a Ron Davis? Any idea how it compares costwise and build quality?
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 05-29-2013   #4
WydGlydJim
WydGlydJim's Avatar
There are several options out there.......most are north of $500 and most have thicker cores. The thicker core is a good thing, but requires trimming the fans shroud. This radiator is not a thicker core, but the tanks are said to provide more capacity, and the website says it provides 50% more cooling surface over stock, with no modifications.
I really like the all aluminum construction over plastic end tanks.
2009 LS9
1973 LS4/sold
Old 06-04-2013   #5
TCurtner
Do you have links to the place you purchased? Would sure like to look into this option/price point.
Thomas (looking towards my own LT5 designation :-))
TCurtner is offline   Reply With Quote
Old 06-05-2013   #6
1991ZR1
I went with the Fluidyne. I don't remember what it cost but it was expensive. Looks good though. Once installed, you can't see it anyway.
If you get this radiator and you have Samco hoses, the top hose will be difficult but not impossible to install. I had to grease the inlet pipe with silicone and make a shoe horn out of a piece of a plastic bottle which I also greased to get the hose on. I'm not sure if residue from that silicone getting into the coolant is ok or if it will cause a problem later.
1991ZR1 is offline   Reply With Quote
Old 06-05-2013   #7
WydGlydJim
WydGlydJim's Avatar
We ordered directly from Dewitts. Took a couple of weeks. This is a relative new product, and I don't think they keep very many on hand.....may even be made to order.
http://www.dewitts.com/collections/c...minum-radiator
2009 LS9
1973 LS4/sold
