Thanks for photos of that set up
![]() What was the condition of the Ball Joints you replaced and how many miles? And......what was source and specific Ball Joint you replaced with? Cliff
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 05-27-2013 at 11:33 PM. |
#3 | |
No, I did this because Pete noticed my upper A arms were installed backwards. IOW, Left was on the right and vice versa. I know I re-installed the arms the way they came off when I did the bushings so I must have gotten the car that way. Never thought to look. Now that dyno runs were completed and before th 1/2 mile, I wanted to make certain everything was correct. A-arms are now swapped into correct positions and going for alignment this week. Last edited by XfireZ51; 05-27-2013 at 11:44 PM. |
![]() ![]() Join Date: Feb 2010
Nice setup, Dom.
![]() Join Date: Feb 2011
I've had good luck with this tool to separate the lower ball joint. I always like to see alternatives before beating the crap out of it with a pickle fork and hammer.
http://www.jegs.com/p/Specialty-Prod...55963/10002/-1 |
#6 | |
![]() Join Date: Jan 2009
Your puller idea is what I was hoping for. And I just happen to have a Craftsman puller just like the one you show. Thanks again.
#7 | |
I've had good results using this $16 pitman arm remover form Northern Industrial
