Old 05-22-2013   #1
Tony Davila
Tony Davila's Avatar
Default Tony D's Project corner (Heat extraction vents)
Some of you guys were wondering about my heat extraction vents that I made and I would like to share my endeavors with whom ever is interested.
---------------Project: Heat extraction.
Step 1: Design any pattern you desire to be cut out on your upper inner fender. Make a template then use a Dremel cutter or anything else that will cut plastic.
Step 2: Cut down the screen mesh to size. I went to Lowes and bought some gutter screen and this is what I used.
Step3: I used epoxy to attached the mesh to the back side of the opening. I did this back in 2003, it still is in tack.
This works pretty good at allowing the heat to escape. You can actually feel the heat roll out of the fender. I have not had any issue with water being splashed up inside of my engine compartment because of the pressure created from the movement of air from the radiator. So it works very well.
Tony Davila is offline   Reply With Quote
Old 05-22-2013   #2
Default Re: Tony D's Project corner (Heat extraction vents)
Tony
That's awesome!
This kind of stuff is great for the newsletter!!
Old 05-24-2013   #3
Coupe89
Nice...
I did fans on mine a last year
1990 ZR-1 #642
Coupe89 is offline   Reply With Quote
Old 05-24-2013   #4
Schrade
Paint the screens BLACK!!!
That would look nasty!!!!!!!!! (all except for the missing feathers on those chicken legs )
