![]() Join Date: Apr 2013
Well I finally had time to get to work on this car today. Had to run it to dealer this am so they could fix the antenna they screwed up a couple weeks ago while working on the 3rd brakelight..
![]() ![]() ![]() ![]() ![]() I also got all the glass Rain-X'ed and cleaned on the inside. I'm one tired puppy right now...LOL Last edited by Racinfan83; 05-10-2013 at 08:45 AM. |
![]() Join Date: Feb 2011
That screen will pay dividends later on for sure. C4's snort more junk than a coke addict.
![]() Join Date: May 2011
Check your oil level, they may think SBC, 5 qts
There are many articles on Mobile 1 and the lack of zink and phosphorus in their formula.
![]() Join Date: Sep 2012
Thanks for the write up on the debris screen. I was headed to HD tomorrow to see what I could use. I'll be making one this weekend.
![]() Join Date: Sep 2011
Great timing .. I am in the process of making a couple screens myself. I have a friend who is a metal worker that is getting me some stainless mesh.
#8 | |||
Already did - it is actually a bit overfull - but the Fram filter that was on it had no anti-drainback valve on it. So I think since I put the correct AC filter on - it should be pretty close to perfect. Quote:
![]() I was going to drill the bottom of the air dam to zip-tie across the front - but I had to take some of the air dam bolts out as the piece was pulled out of the bolts from hitting curb stops or speed bumps or whatever. Made me think that if I hit something with the air dam it would rip the zip ties through the screen - so I left that loose.... Last edited by Racinfan83; 05-10-2013 at 09:45 AM. |
#9 |
Check both headlights' mounting brackets for a lonesome mounting stud. Then stick your finger in each center hole, hood underside, where the C4 emblem is in the front.
Got a pic of the nut? Is it a machine nut? With integrated swivel washer? Or just a 'shell' of a nut (don't know the proper name for them) ... |
#10 |
It was a black 10mm nut with a swivel washer on it. Funny thing is that one of the air dam bolts had a nut jammed on it that was too small. Drove me nuts
