Planning to reassemble Wed or Thurs this week after pulling secondaries.
Quick count got me 35 or so electrical plugs that need to be reconnected. Do you all use anything on them, generally speaking or just plug everything back together dry? Dielectric grease on plug wires and grounds, anything else for all the other connectors? FSM does not usually say to use it, but does not say not to use it either. Thanks |
![]() Join Date: Dec 2003
It wont hurt as its all about continuity. I typically use it on plug boots and weatherstripping
Should I put it on the plug wire to coil boot?
Plenum goes on tomorrow. Thanks |
![]() Join Date: Jan 2007
Give me a shout if you need any assistance.
A light amount wont hurt
