![]() Join Date: Jun 2004
Recently many have complained about the hood props falling down do to wind, bumping, etc. Well, no longer will you have to worry about the hood falling on your head. CT Machining has manufactured an item that gaurantees that the hood will NOT fall if you use the item they have invented. The item is made of 6061 T6 aircraft aluminum and fits in your pocket. You will be proud to own and display this item.
There will be a group buy running thru next Thursday for the "Hood Prop Stop" C4 Hood Prop Stop - 1.JPG C4 Hood Prop Stop - 4.JPG C4 Hood Prop Stop - 5.JPG C4 Hood Prop Stop - 6.JPG The price is $15 (delivered to BG) and $18 shipped. You asked for them and they are now here. Thank you, Carter ![]() PS: Minimum order of 15 to have them delivered to BG......
95 ZR-1 BLK/Gry #392 LT5 Reg# 868 *RIP* ZR1NET Founding Mem #155 Last edited by carter200; 05-03-2013 at 07:35 PM. |
![]() Join Date: Jan 2009
On my 90 there is no notched area on the lower tube.
Is that necessary for the piece to fit?
Scott,
I see the notch you are talking about and your rod may not have the notch but the rod has to sit on top of the bottom tube and this item will still work just fine.
![]() Join Date: Oct 2008
Can't see the photos
Jim |
I'm in Carter that's 1
Thanks GC. Knew I could count on you...........
The hood prop looks nice , I'd like to have one. I'm not going to Bowling Green, and I don't have Pay-Pal. How do we do this? Thanks.
I'll PM you the paymetn info.......
#9 |
5 of the 15 needed ordered so far. Thanks to all who ordered and to those who are about to do so.......
#10 |
I am already in for three hood props.....GC....you need more ZR-1s
![]() Just wait untill I show Carter my Billet Aluminum Fuel Line Clamp ![]() ![]() ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 05-03-2013 at 09:26 PM. |
