Old 05-02-2013   #1
Paul in SC
Paul in SC's Avatar
Default Exhaust versus Power versus HP
from secondchance in previous thread
Re: Group Buy Stainless Works.
With headers, no cats and 94 stock exhaust it registered 1.4 psi @ 6000 rpm.
Same with free flow exhaust (OBX in this case) dropped to 1 psi.
Yun,
Let's start there and the first question I have is what mods and HP for the engine tested?
Thanks for adding comments. I hope you don't mind the new thread.
Paul
1993 ZR-1 - "The Green Thing", LPE/LSV 385; 2021 HTC, Red Mist Metallic, Cool gray interior, stainless dual stripes; ZR-1 Net Registry #1376
Paul in SC is offline   Reply With Quote
Old 05-02-2013   #2
Meanmyz
Meanmyz's Avatar
Default Re: Exhaust versus Power versus HP
From the SW thread... Paul I guess I was asking because I was considering the pros and cons of doing this myself (headers, cats, and stock resonator and mufflers).
So again the question to anybody will to chime in: If Marc H lists 5 HP as the difference between the second design stock exhaust vs. a freer flowing exhaust, does this difference widen as you modify the car for more power, such as 500HP?
...with the answer leading to "yes it only makes sense to also add a free flow exhaust because you are only mitigating the effects of some of your mods" or "no, there won't be a noticeable difference".
Meanmyz is offline   Reply With Quote
Old 05-02-2013   #3
secondchance
Yun,
Paul
94 405 hp stock motor. Headers and OBX exhaust w/ Marc Heibeck chip turned 363 rwhp and 340 rw lb-ft.
OBX is 2-1/2" stainless steel system.
Old 05-02-2013   #4
secondchance
Conventional wisdom is to go to 3" exhaust once above 450 hp. To answer your question - yes. Difference will widen. Higher hp means more exhaust volume.
Old 05-02-2013   #5
efnfast
1990, 375 stock hp. Headers, no cats, OBX exhaust, Marc H chip. 353 rwhp.
Old 05-02-2013   #6
1990 quasar blue
1990 ported plenum/injector housings. SSW headers, random technology cats, flowmaster catback. HAT tune. 390 rwhp/360 rwtq. SAE.
Old 05-03-2013   #7
Fully Vetted
Fully Vetted's Avatar
1994 ported, SSW headers, no cats, Magnaflow catback, Corey Tune. 430 rwhp/392 rwtq
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 05-03-2013   #8
350, Haibeck 510 pkg minus Fidanza and plus ceramic cats. Top end/head porting, 63 mm throttle body, SSW headers, Corsa. 413 RWHP. Fidanza aluminum flywheel would add 13 RWHP and no cats would add another 10 or so.--Bob
Old 05-03-2013   #9
Raptor Twin Turbo
Stock 405 HP 93'
360 rwhp & 340 rwtq
No port, No headers, stock CATs & exhaust.
MS/Raptor ECM with MS tune.
Raptor Twin Turbo is offline   Reply With Quote
Old 05-04-2013   #10
It is all in my signature except to add this re the exhaust
3" dual exhaust (except mufflers...but that is going to change!)
