Old 03-31-2013   #1
Rex Ruby
Default DTC 32 EGR
I keep getting the service engine light.
Pulled DTC 32.
FSM says I need a Tech1 to diagnose.
Anyway to diagnose w/o a Tech1?
How do you get at it w/o pulling the engine?
Rex Ruby is offline   Reply With Quote
Old 03-31-2013   #2
vilant
Default Re: DTC 32 EGR
In the 1990 FSM, 32- EGR system error is for the L-98. There is a CCM error 32, not sure if it's the same for a '94.
Old 04-01-2013   #3
Rex Ruby
I think it's different for '94.
I verified with the FSM bu that doesn't mean the FSM is always correct.
Thanks Joe.
Anyone ever pull the EGR???
Old 04-01-2013   #4
Jagdpanzer
Jagdpanzer's Avatar
EGR valve pintle may be stuck causing the ECM to throw a code 32.
FSM test procedure using a Tech1 can confirm proper EGR function before you start taking things apart. The EGR valve is a bear to get at. Have to unbolt and jack up the right side of the engine.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 04-04-2013   #5
Hib Halverson
The 93-95 EGR valve is difficult to remove but you don't have to pull the engine. As Phill suggests, you need to disconnect the engine mounts and jack up the right side of the engine.
You cannot diagnose DTC32 w/o a TECH1, Mastertech or TECH2. .
But, before you do all that work, if you don't own a T1, Mastertech or a T2, I'd take the car to a shop that does and have them troubleshoot the EGR with a tester. That way you'll know for sure if you need to replace the valve before you go to the trouble to lift up the engine.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 04-05-2013   #6
Rex Ruby
Thanks for the replies.
Going to put a Tech 1 on it tomorrow at Carlisle.
