Old 03-08-2013   #1
xlr8nflorida
xlr8nflorida's Avatar
Default Master Cylinder Help on 95 ZR-1
The NOS Master is like finding Hen's teeth and its different then 90-91.
When you change out the Master, you need to transfer the switch from your old unit to the new unit.
The problem is the switch on the bottom of the 95 cylinder is big and all of the replacements (Rock Auto) have small spots for the switch and the original switch won't fit?
What do you do?
If I could figure out where the master came from, I could figure out a switch that work work.
What is the work around?
Old 03-09-2013   #2
WVZR-1
Default Re: Master Cylinder Help on 95 ZR-1
What do you do?
See your other post just like this on the CF:
http://forums.corvetteforum.com/c4-z...p-on-95-a.html
