Old 03-04-2013   #1
Rex Ruby
Default Oil Leak
Have a leak where the oil lines connect in front of the radiator.
Bad hoses or could it just require some tightening?
Rex Ruby is offline   Reply With Quote
Old 03-06-2013   #2
z proud
z proud's Avatar
Default Re: Oil Leak
John, the oil lines are a know problem for leaking on the earlier cars, 90 to 91' I would remove the center bolt an replace the O rings to see if that does not fix yours.
Good luck
z proud is offline   Reply With Quote
Old 03-08-2013   #3
Rex Ruby
Will do, thanks Bill!
Old 03-10-2013   #4
Good luck
It appears you are talking the ZR-1 Oil Cooler Lines (SS shown). That be ZR-1 Technical Postings
Make sure the fittings are tight as z proud suggests
What I do on oil pan gasket, water pump gasket or any gasket in contact with oil or water (including "O" ring mating surfaces) is use a light coat of Permatex.....NO LEAKS after that
I coat each side of gaskets very lightly with Permatex and let it get tacky....then just place the gasket on any surface and it sits there without holding or moving as I insert bolts into the components.
Now when you go to remove those "Permatexed Gaskets", it is no fun but then I rarely have to remove those gaskets.
NO...do NOT use Permatex on Head Gaskets
Old 06-16-2013   #5
Rex Ruby
Finally got around to installing O rings and it worked great!
Thanks all.
