Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 ZR-1 NCRS Topics
Old 03-04-2013   #1
vettn71
Default Jerry's Plenum Gaskets
Just installed ASET of Jerry's thicker plenum gaskets on my 1990 ZR-1. I had a set from Kurt, but got hit in judging for them. Not sure what he issue was, as my wife was with the car when it was judged. Jerry worked up a set of beige thick gaskets for my plenum. I compared these to my original plenum gaskets and the thickness, when installed is just right and they are almost indistinguishable fom the originals
Thanks, Jerry or a great job and super service.
vettn71 is offline   Reply With Quote
Old 03-04-2013   #2
Kevin
Kevin's Avatar
Default Re: Jerry's Plenum Gaskets
they dinged you from plenum gaskets? what did they do, pull the plenum?
Old 03-04-2013   #3
vettn71
Some way they did not have the right configuration. I haven't really matched them up with the originals, but if they don't appear the same as the originals hen installed, that's a deduct. It's only a point or two, but I'm going for a McClellan in July.
Old 03-04-2013   #4
Kevin
Kevin's Avatar
you're a better man then I am jim
Old 03-04-2013   #5
vettn71
Kevin
I had to go under to clean and replace the air box gasket, also. This makes the fourth or fifth time for a plenum pull. Glad it's pretty simple
