Old 02-26-2013   #1
Brad Sewell
Default Look what I found...
Wrapped and sealed. The old girl keeps giving up new surprises.
Brad Sewell is offline   Reply With Quote
Old 02-26-2013   #2
vilant
Default Re: Look what I found...
Can't see your pic Brad. For some reason it works better if you save it to an album in your User CP, first. Then copy and paste the whole [IMG][IMG] from the pic in the album,to the post.
Old 02-26-2013   #3
Kevin
Kevin's Avatar
tire pressure gauge.
cool
Old 02-27-2013   #4
LancePearson
LancePearson's Avatar
As I've been removing tunnel trim to check shift boots and then the center console trim to pull and redo the radio head and add some resonance killing .080" urethane sound proofing to the plastic under the radio and trim I used a 24" extendible probe with magnetic head on it and found every single screw and clip that had been dropped over the years as they "clanged" to the magnet from recesses my fingers would never see or reach! Best tool ever. I actually got two 12" long forceps from Amazon yesterday for $12 which are also great. Next winter I pull the seats to switch them and maybe redo the leather on the driver's side...wonder what I'll find under them from P.O's? I found about $0.75 as well...but that won't buy much nowadays.
LancePearson is offline   Reply With Quote
Old 02-27-2013   #5
ghlkal
ghlkal's Avatar
Good idea. I'll be pulling my console and bezel soon, so thanks for the tip.
