![]() Join Date: Feb 2013
Hello. I have two 1993 LT1s, but just purchased a 1990 black ZR-1 with 33K miles and have some code/electrical issues I need help with.
My issues are:
Thanks for the help.
______________________________________MarkF 1990 Black ZR-1 #0543 |
![]() Join Date: Nov 2011
Can't help with the issue's, but there are plenty of people here that can. But welcome, I also have a black 90, ain't they beautiful? Somebody will will post up shortly to help with the issues. Welcome aboard. -Steve
![]() Join Date: Dec 2003
Could be a grounding issue. But first I would reset everything. Reset the codes and disconnect the battery for a minute. Then as issues come up check for any codes and address that code. You might also reseat the Prom. A 1990 with 33K miles could be one that has sat around quite a bit so you might have a corrosion issue with connections.
ZR-1 Mom Founder ZR-1 Net Registry Founder ZR-1 Net NCM Lifetime Member |
#4 | |
Thanks Mom. It was driven only 1500 miles in the past 12 years. I disconnected the battery and checked the ECM and PROM for corrosion and tight connections this morning. No difference in the DIC lights, but I did not re-check the codes. How do you re-set the PROM? Thanks again.
![]() Join Date: Feb 2009
Mark,
Regarding the INFL REST light, I just fixed that on my car, it a corrosion issue where the airbag sensors are mounted on the fraime. A code 16 is the drivers side sensor and it's mounted on the frame behind the battery. The code 26 is the passenger side senser and it's mounted on the frame behind the windshield wash bottle. Both senser need to be remove and clean the frame where they mount. My sensor had rust under both, I scrubbed with a wire brush, and remounted using di-electric grease. Then you have to clear the code in the computer. There is a thread on that, it's fairly involved. I used my tech 1A to clear it. Rich
ALDL CODE-CLEARING TECHNIQUE
When using this code-clearing technique, a digital wristwatch can be quite helpful. The timing sequence discussed below is very important to successfully clearing codes. The watch can help you with timing the 3-second intervals more exactly. 1.Turn ignition "OFF". 2. Ground ALDL terminal "K". 3. Turn ignition "ON". 4. Wait for codes to begin flashing (approximately 5 seconds). When codes begin flashing, unground ALDL terminal "K" for 3 seconds +/- 1/2 second. 5. After ungrounding terminal "K" as described in Step 4, ground it again for 3 seconds +/- 1/2 second. 6. Unground ALDL terminal "K", and wait 10 seconds. Before turning ignition "OFF", verify that Code 12 flashes six (6) times. If Code 12 does not flash six (6) times, codes have not been cleared properly. Begin clearing procedure again starting with Step 1.
#7 | |
![]() Join Date: Jan 2009
you'll need to prioritize which defect you want to hit first. Then I'd use the search feature of this forum for threads that cover it. (homework) Armed with that you can begin probing whichever issue you want to resolve with a new thread. Or you may get lucky and find a fix in an old thread. There is a ton of help at: http://zr1netregistry.com/Informatio...ticles%5D.aspx
#8 | ||
![]() I have already found a thousand fixes in "old threads" ![]() Or.....if you like...."new fixes" in a "new thread".....second resource ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-25-2013 at 11:00 AM. |
#9 |
You can search years worth of info here http://maillist.corvettemuseum.com/c....exe?A0=ZR1NET
#10 |
![]() Join Date: Jan 2012
Hi Mark, you've received some great advice so far. Yes, it's certainly possible that you have all of those issues. My 90 with <50K miles had a similar number of issues when I bought it last year.
Lots of good resources. I will second Cliff's (Dynomite) recommendation to use his Solutions link. |
