Old 02-19-2013   #1
sdickens
Default Not sure where these hoses go and if there is a hose missing.
I have a 1990 ZR-1 and while working on an issue with my headlights not working properly I found some other issues.
First and second picture are two ends of a hose that are off a T connector where the start looks like it is coming from what looks like it says Purge Valve on it, but I am not certain what it is.
But I cannot find where the ends of these tubes plug into.
https://lh5.googleusercontent.com/-U...p-o-k/Pic1.jpg
https://lh6.googleusercontent.com/-0.../s748/Pic2.jpg
This next photo looks to be the Switch Valve Assembly and it looks like there is a hose missing from it, but I cannot seem to locate one.
https://lh5.googleusercontent.com/-j.../s748/Pic3.jpg
Any thoughts?
Thank you!
sdickens is offline   Reply With Quote
Old 02-19-2013   #2
scottfab
scottfab's Avatar
Default Re: Not sure where these hoses go and if there is a hose missing.
None of you pics are coming through to me.
Scott
Old 02-19-2013   #3
sdickens
I updated, maybe you can see them now?
Thanks
Old 02-19-2013   #4
The third picture of the nipple next to the leftside head is open,at least it is on my 91 and Ive had the car since its had 6000 miles.Not sure about the first 2 hoses.
Old 02-19-2013   #5
That is an abandoned A.I.R system.
Old 02-19-2013   #6
sdickens
Thanks, I feel better about that!
Old 02-19-2013   #7
sdickens
Do these just need to be capped off? i had the car running and didn't feel anything when holding my hand over them.
Thanks!
Old 02-19-2013   #8
Thanks!
Very Welcome. You can leave tubes there uncapped. Or if you like take the entire A.I.R system out.
