Old 02-12-2013   #1
Vetman
Vetman's Avatar
Default Hollywood
Has there ever been any consideration of a movie or at least a documentary of the Lt 5 development, production, and record endurance run at Fort Stockton. As I read the book "heart of the beast" it reads like a movie.
Vetman is offline   Reply With Quote
Old 02-12-2013   #2
LancePearson
LancePearson's Avatar
Default Re: Hollywood
I've seen reference to a dvd of the run by a member who sold them to members a while back but I tried to find one and so far have not. I too would love to see this...the photos of the engine assembly in Stillwater in the book, HOTB, are great. I keep realizing how special this engine is. The other day I saw the exploded view of the block and its parts and realized finally what they meant by a ladder bottom then did some more research into how that helped make it rigid and what two versus four bolt traditional journals meant with their little bolts. This thing has 1/2" bolts that snug that bottom ladder bracket in plus all the outer bolts and are way more substantial than the iron block engines with two or four bolt mains holding the journals for the crank bearings. A two part block plus oil pan with baffles and then the heads. It just keeps getting better. Ferrari uses a 64 degree v 12 which would be taller than our 90 degree v8 but they use a dry sump oil system to shorten the whole thing. Their dohc v12 6.3 litre fits under the hood of their F12 Berlinetta which the C7 stock two valve pushrod 450 hp engine does and which are virtual copies of the bodies. Theirs dumps 730 hp with the dohc technology. I think we own something so unique in Vette terms and an opportunity lost for them that these cars are really special. The vast majority of Corvette owners have no clue about these and many are lost in the myth that the C4 isn't good. If I hadn't seen a black ZR-1 at local shows and started wondering I probably would have accepted that since I also own a 76 bright red four speed l48.
Lance P.
Lance
LancePearson is offline   Reply With Quote
Old 02-12-2013   #3
That would be a great documentary ! Not only for LT5 aficionado's but also to the entire automotive industry.
Old 02-12-2013   #4
Vetman
Vetman's Avatar
Question Re: Hollywood
If anyone knows where I might purchase the DVD mentioned in the above response from Lance, please let me know.
The only flaw really in a c-4, aside from having to "shoe horn" yourself into and out of the car is the squeaky targa top. Does anyone have any solutions to the squeaks......
Old 02-12-2013   #5
LancePearson
No squeaks in mine...clean rubber gaskets and uniiform bolt tightness
Old 02-13-2013   #6
SteelBlueZR1
C4 Top anti squeak pad kit: http://item.mobileweb.ebay.com/viewi...d=140395515394
Old 02-13-2013   #7
No squeaks in any of my ZR1's. Take the top off. Clean and silicone lube all rubber weather-stripping including pins , adjust fit then tighten adjustement fittings. Then tighten top evenly (not too tight) .
The process may take a good half hour. Time very well spent.
Old 02-15-2013   #8
Vetman
Vetman's Avatar
Guess I should have checked closer. The front adjusting bolts were lose.. Tightened them and presto, no squeaks. Thanks!
1990 Z # 2441
1959 c-1 230 HP 4 speed frost blue/silver 3 owner
2011 cts-v 556 HP, manual 6 speed
1955 chev 2dr ht PP 265 3 speed w/OD
Old 02-16-2013   #9
USAFPILOT
USAFPILOT's Avatar
mine only makes noise going in and out of my driveway, which has a low curb I must climb over. The car basically twists and I can hear it make groaning and creaking noises. After that I don't hear anything, but a slight wind noise from my painted top, nothing from the clear one. I guess I will try those pads, but I think my creaking and groaning comes from the halo itself.
Old 02-16-2013   #10
"creaking and groaning comes from the halo itself"
If I was closer , find it and solve the problem in minutes for you. Going to BG ??
