Old 02-03-2013   #1
Brad Sewell
Default DC battery for light bulbs
The fsm says to disconnect the negative battery terminal to replace the chmsl bulbs and the backup lamps.
Is it really necessary to disconnect power to replace a bulb?
Brad Sewell is offline   Reply With Quote
Old 02-03-2013   #2
vilant
Default Re: DC battery for light bulbs
The FSM says that on just about every maintenace procedure. Generic safety precaution which I think is necessary sometimes and not so much other times, IMO. Unless your worried about someone jumping in the car and pushing the brake pedal or turning on the headlights, while your changing it. I think you'll be just fine.
Old 02-03-2013   #3
scottfab
scottfab's Avatar
You should brush after every meal also.
Scott
Old 02-03-2013   #4
secondchance
I didn't. Just wear a glove and avoid touching the bulb with bare fingers. Oil from fingers will burn out the bulb.
