Old 02-02-2013   #1
Schrade
Default Underhood fuse block?
Is there one? Where? (too much dust on the FSM )
Old 02-02-2013   #2
WVZR-1
Default Re: Underhood fuse block?
Not a "fuse block" - there's several fusible links near and behind the battery, the primary fuse block is right side of dash and under the right side of the dash there are 3 - 4. There are relays everywhere!
Old 02-02-2013   #3
Schrade
ALL fuses pulled, and still a draw.
I still hear a click too, when I make contact with the multimeter probes!!!!!!
And the click is FELT in the headlight manual rotation knobs; both sides.
Where is the relay for this headlight motor circuit???
WE ARE CLOSE!!!!!!!!!!!!
Old 02-02-2013   #4
Schrade
EUREKA!
Old 02-02-2013   #5
WVZR-1
Put the H/L control module back in and then check each H/L seperately for the draw at the H/L motor.
